[Qgis-community-team] rst: definition of QGIS Tips
Paolo Corti
pcorti at gmail.com
Thu Jul 5 03:25:18 PDT 2012
On Wed, Jul 4, 2012 at 4:25 PM, Larissa Junek <junek at gbd-consult.de> wrote:
> On Wed, 4 Jul 2012 15:49:05 +0200
> Paolo Corti <pcorti at gmail.com> wrote:
>> On Wed, Jul 4, 2012 at 3:26 PM, Larissa Junek <junek at gbd-consult.de>
>> wrote:
>> > Hello Paolo and others,
>> > did we already discuss what to do with the QGIS Tips?
>> > So far, we define tips as the following:
>> > .. tip::
>> > **Creating a vector layer from a Microsoft Excel Worksheet**
>> > Yet this formulation does not work. Can somebody help?
>> > Cheers,Larissa
>> Dear Larissa
>> your formulation is correct.
>> It is a problem with the custom theme we are using (qgis-theme).
>> You can check this yourself using the default sphinx theme, just
>> change:
>> html_theme = 'qgis-theme'
>> in
>> html_theme = 'sphinxdoc'
>> in the source/conf.py file
>> cheers
>> p
> Hi Paolo,
> is it possible you include the definition for tip in the 'qgis-theme' in
> the near future?
> Thanks.
> Cheers
> L
Hi Larissa
I would suggest, for now, to switch to the mentioned sphinx theme, at
least we are sure that everything should be covered.
We will then update accordingly the qgis theme (now I am on very busy work load)
cheers
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the Qgis-community-team
