[Qgis-community-team] Fw: rst conversion: problem with references
Larissa Junek junek at gbd-consult.de
Tue Jul 17 04:03:02 PDT 2012
On Mon, 2 Jul 2012 14:02:35 +0200
Paolo Corti <pcorti at gmail.com> wrote:
> On Mon, Jul 2, 2012 at 11:22 AM, Larissa Junek <junek at gbd-consult.de>
> wrote:
> > On Thu, 28 Jun 2012 16:26:18 +0200
> >> On Wed, Jun 27, 2012 at 4:03 PM, Larissa Junek
> >> <junek at gbd-consult.de> wrote:
> >> > Begin forwarded message:
> >> > Date: Wed, 27 Jun 2012 15:59:57 +0200
> >> > From: Larissa Junek <junek at gbd-consult.de>
> >> > To: qgis-user at lists.osgeo.org
> >> > Subject: rst conversion: problem with references
> >> > Hi all,
> >> > while the call for a reference works fine when I deal with
> >> > figures, the link to a section doesn't work.
> >> > For example in the plugins_gps.rst I defined:
> >> > "... see section `defining-new-device`_" this is the call for the
> >> > reference
> >> > ".. _`defining-new-device`:" this is the reference
> >> > Can somebody help? What did I do wrong.
> >> > Kind regards,
> >> > Larissa
> >> Larissa,
> >> this is the correct syntax:
> >> a new type (see section :ref:`defining-new-device`).
> >> .. _defining-new-device:
> >> Defining new device types
> >> cheers
> >> p
> > Hi Paolo,
> > the call for the reference still doesn't work.
> > Maybe you have a look at the plugins_gps.rst I committed. I want to
> > call the reference in the same page, not in another page. Therefore
> > I thought that we might need another definition, like it is
> > described in the README.rst
> > I have this problem in other rst-files, too. Look forward to
> > finding a solution.
> > Cheers, Larissa
> Hi Larissa
> you need to leave an empty line just after the section declaration:
> (empty line here)
> cheers
> p
Hi Paolo,
this convention works fine for sections as as well as for figures. I'd
like to go on using it in the rst-files
Can you document this subject in the README and the wiki? Then we all
proceed the same way.
Thanks,
Larissa
More information about the Qgis-community-team mailing list
