[Qgis-community-team] QGIS Server supported CRS
Jürgen E. Fischer
jef at norbit.de
Sat Mar 24 05:34:03 EDT 2012
Hi Paul,
[please use the qgis-user list for usage questions]
On Fri, 23. Mar 2012 at 21:28:58 +0000, Paul Shapley wrote:
> I'm using QGIS 1.7.4 on Ubuntu 11.10 and i've set up a WMS but the WMS layers
> have not inherited the projects' crs (EPSG:27700) they keep defaulting to
> WGS84. The ability to search and change the CRS is prevented. Is there a
> workaround?
That dialog only shows the CRSes the WMS server offers. Once the WMS layer is
inserted you can change its CRS. With on-the-fly-projection enabled QGIS will
then reproject into the newly selected CRS, although the WMS will still deliver
the data in the initial selected CRS.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the Qgis-community-team
