[Qgis-community-team] conventions about sections
Otto Dassau dassau at gbd-consult.de
Wed May 16 06:00:41 EDT 2012
Am Wed, 16 May 2012 11:49:12 +0200
schrieb Larissa Junek <junek at gbd-consult.de>:
> Am Tue, 8 May 2012 12:46:16 +0200
> > Hi Jean-Roc and Alex Bruy,
> > working on the new rst-Documents I analysed the way we structure
> > sections. At the moment we use --- for chapters, === for subchapters,
> > *** for susubchapters  and ~~~ for sections. I'm o.k. with that but
> > how does this convention fit together with the conventions in the
> > http://sphinx.pocoo.org/rest.html#external-links ?
> > Here the --- is one lever lower than the === ... Somebody who can help
> > me understandig ? If you have further definitions can you add them in
> > the README.rst ?
> > Kind regards,
> > Larissa
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Hi all,
> the automatic translation didn't bring up a good solution for
> sections, it seems to be a little mixed up. I would suggest to proceed
> the following way:
> Chapter   Section   Subsection   **Minisection**
> --> Example:
> Using QGIS Core Plugins
> OpenStreetMap Plugin
> Basic User Interface
> **OSM Features widged**
> Would that be ok?
> Kind regards,
> Larissa
Hi Larissa,
I like that idea - 3 TOC levels are enough. And since \minisec{} in latex
also didn't appear in the TOC the **solution** would mean the same in rst.
Regards
Otto
More information about the Qgis-community-team mailing list
