[Qgis-community-team] Qgis-community-team Digest, Vol 64, Issue 2
Hien TRAN-QUANG
hien.tranquang at gmail.com
Thu Jul 4 14:20:20 PDT 2013
Hello,
I took a week of vacation just after your reply, and I've been in quite a
rush lately. But now everything is becoming ok. I began to update the print
composer chapter. As I test and check on the way, I found a bug for which I
filled a report 2 days ago.
I planned to completed a little more text before I pull a request, but if
you prefer, I can pull now my work in progress. Maybe it is easier for
everyone as one can see I'm still alive.
Just one question : do I need to take screen caps or is someone in charge ?
Regards.
Hien.
Message: 1
> Date: Thu, 4 Jul 2013 09:48:10 +0200
> From: Otto Dassau <dassau at gbd-consult.de>
> To: qgis-community-team at lists.osgeo.org
> Subject: Re: [Qgis-community-team] Looking for help to update the
> englisch manual (Otto Dassau)
> Message-ID: <20130704094810.6c15e9f5 at nature.speedport.ip>
> Content-Type: text/plain; charset=UTF-8
> Hi Hien,
> I haven't heard from you again after I sent you the list of features, that
> need to be added to the print composer? Are you still interested to work on
> it? Do you have questions or problems to start?
> Kind Regards
> Otto
> Am Fri, 14 Jun 2013 12:19:00 +0200
> schrieb Otto Dassau <dassau at gbd-consult.de>:
> > Hi Hien,
> > if you have a look at the manual task list:
> > http://hub.qgis.org/wiki/17/ManualTasks#Updates-QGIS-20-User-Guide
> > There are several features listed for chapter "print composer" at the
> > bottom now. I added your name to the lines and extended the list to what
> I
> > think needs to be added/updated for the print composer.
> > * snap to left/mid/right coordinates of other items when moving composer
> > items for alignment
> > * custom linestyle for composer grid
> > * add support to SVG images from url
> > * new element "add html frame"
> > * Support for creation of map atlasses (new tab)
> > * possibility to show composer map grid coordinates in
> > degree/minute/seconds
> > * Multipage compositions
> > * split legend in several columns
> > * Display rectangle of another composer map (overview map)
> > * Zebra style for composer grid (black/white pattern at borders)
> > * New Rendering menu with several blending modes (here Larissa has more
> > information)
> > * General new structure of the item property tab for all elements
> > * describe item ID feature in element tab (was already in 1.8)
> > I would suggest you start using the master branch and send pull requests
> > for your changes, so we can have a look. Is that ok for you?
> > Thank you very much for your help and don't hesitate to ask, if there are
> > questions.
> > Regards
> > Otto
> > Am Fri, 14 Jun 2013 11:40:55 +0200
> > schrieb Hien TRAN-QUANG <hien.tranquang at gmail.com>:
> > > Hello,
> > > I'm replying to Otto's call for help on the QGIS users mailing list.
> > > I just started helping translating the 1.8 manual in French at FROG's
> > > Code Sprint a few days ago.
> > > I would like to help you release new QGIS 2.0 as soon as possible. So
> > > here I am.
> > > My preferences go to print composer, so if someone can tell me which
> > > features I can work on.
> > > Hien TRAN-QUANG
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Geoinformatik B?ro Dassau - http://www.gbd-consult.de
> FOSSGIS consulting , training , support and analysis
> Ackerstrasse 144c , D - 40233 D?sseldorf , Germany
> Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
> Community Advisor - QGIS Project Steering Committee
> End of Qgis-community-team Digest, Vol 64, Issue 2
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130704/8c689e6a/attachment.html>
More information about the Qgis-community-team
