[Qgis-community-team] Manuals and help
samuelmesa at gmail.com samuelmesa at gmail.com
Wed Jul 10 17:52:00 PDT 2013
I managed through a small Python script to get some the html help of SAGA in
the sextant syntax:
Script [1]: http://paste.ubuntu.com/5863377/
Sextant html file [2]: http://goo.gl/Sr12A
But there are some html files with errors due to special characters such as
"/, (,)" in command names.
To test this help should only copy the folder in the path:
/usr/share/qgis/python/plugins/sextant/saga/
I hope this can be a small solution for the moment.
Regards,
Samuel Mesa.
2013/7/10 samuelmesa at gmail.com <samuelmesa at gmail.com>
> Paolo, recently I'm trying to explore the help of SAGA for Sextante, and
> I've seen that you can extract the documentation from SAGA GIS through the
> following command:
> saga_cmd [-d], [--docs]   : create module documentation in current working
> directory
> Which you can get the following HTML files:
> http://goo.gl/0WhTj
> I have seen that these files could be located in the folder /usr/share/qgis/python/plugins/sextante/saga/help/
> (Linux), obviously must rename each html file by the name of the command
> of saga.
> However, I would suggest modifying the python file [1] to help organize
> files by folder module and not the entire list of html files in a single
> folder?.
> Thank you,
> Samuel Mesa.
> [1]
> https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/sextante/saga/SagaAlgorithm.py
> #L370
> 2013/7/10 Paolo Cavallini <cavallini at faunalia.it>
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi all.
>> As you know, help is missing for most sextante modules, with the notable
>> exception of
>> GRASS. I'm about to start searching for people interested in contributing
>> help pages.
>> Before doing that, I would like to clarify one point, that could
>> potentially cause a
>> lot of duplication and some frustration.
>> I think the help pages for the modules are also interesting for the
>> manual, so I
>> guess we should decide whether to merge the two (manual and module help)
>> from the
>> beginning, an make one of the two take the pages from the other.
>> I know the style could be different between the two, but I do not think
>> it is
>> realistic thinking someone will write (and maintain) documentation on
>> hundreds of
>> modules, in two different styles.
>> The pages are here:
>> https://github.com/volaya/SEXTANTE-Help
>> What is opinion? The issue is important, as IMHO this is a stumbling
>> block preventing
>> the start of documentation writing.
>> Thanks in advance.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
>> iEYEARECAAYFAlHdlt4ACgkQ/NedwLUzIr5nbwCfZm1Qh+7Ye35/d/U+5Z19tn/2
>> +j0Anjr5z5QPWI5FoBNdH+uJINBZqDHO
>> =mYpB
>> -----END PGP SIGNATURE-----
>> Qgis-community-team mailing list
>> Qgis-community-team at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
>    / v \
   / v \
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130710/47bbaf7f/attachment-0001.html>
More information about the Qgis-community-team mailing list
