[Qgis-community-team] Looking for help to update the englisch manual (Otto Dassau)
    Otto Dassau
    dassau at gbd-consult.de
    Fri Jun 14 03:19:00 PDT 2013
Hi Hien,
if you have a look at the manual task list:
http://hub.qgis.org/wiki/17/ManualTasks#Updates-QGIS-20-User-Guide
There are several features listed for chapter "print composer" at the
bottom now. I added your name to the lines and extended the list to what I
think needs to be added/updated for the print composer.
* snap to left/mid/right coordinates of other items when moving composer
  items for alignment
* custom linestyle for composer grid
* add support to SVG images from url
* new element "add html frame"
* Support for creation of map atlasses (new tab)
* possibility to show composer map grid coordinates in degree/minute/seconds
* Multipage compositions
* split legend in several columns
* Display rectangle of another composer map (overview map)
* Zebra style for composer grid (black/white pattern at borders)
* New Rendering menu with several blending modes (here Larissa has more
  information)
* General new structure of the item property tab for all elements
* describe item ID feature in element tab (was already in 1.8)
I would suggest you start using the master branch and send pull requests for
your changes, so we can have a look. Is that ok for you?
Thank you very much for your help and don't hesitate to ask, if there are
questions.
Regards
Otto
Am Fri, 14 Jun 2013 11:40:55 +0200
schrieb Hien TRAN-QUANG <hien.tranquang at gmail.com>:
> Hello,
> I'm replying to Otto's call for help on the QGIS users mailing list.
> I just started helping translating the 1.8 manual in French at FROG's Code
> Sprint a few days ago.
> I would like to help you release new QGIS 2.0 as soon as possible. So here
> I am.
> My preferences go to print composer, so if someone can tell me which
> features I can work on.
> Hien TRAN-QUANG
More information about the Qgis-community-team
