[Qgis-community-team] screenshots user manual
Werner Macho
werner.macho at gmail.com
Wed Jun 19 13:05:16 PDT 2013
Hi Larissa!
Changes done :) I think it is ok that way ..
But I realised that there are at least 3 different + and - signs into the
iconset .. probably we should consolidate that too?
And the best way I think would be to take the + and - sign that is beneath
every icon that adds or removes something ..
But I could not find that little added icon as a single one ..
kind regards
Werner
On Wed, Jun 19, 2013 at 12:56 PM, Larissa Junek <junek at gbd-consult.de>wrote:
> Hi Werner!
> Yes, good idea. This definitely improves the Look and Feel of the
> plugin. So I will make a screenshot after your improvement.
> Kind regards,
> Larissa
> > Hi Larissa!
> > Bevore doing any screenshots from Topology Checker ..
> > I did not have time yesterday but I wanted to add the usual + and -
> > signs to the buttons or at least change Add New Rule to just "Add
> > Rule" And still the two buttons of Add and Delete should change
> > place .. Probably I will have time today evening to do that ..
> > What do you think about that?
> > kind regards
> > Werner
> > On Wed, Jun 19, 2013 at 12:02 PM, Larissa Junek
> > > Hello,
> > > I currently work on the section "Topology Checker plugin" and want
> > > to insert a screenshot into the text. By doing so there will be
> > > multiple kinds of screenshots in the QGIS user manual 2.0.0.
> > > because also Alexandre Neto creates screenshots for the new user
> > > manual. Are you o.k. with the procedure? I want to continue working
> > > quickly. Thanks.
> > > Kind regards,
> > > Larissa Junek
> > > _______________________________________________
> > > Qgis-community-team mailing list
> > > Qgis-community-team at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Geoinformatik Büro Dassau - http://www.gbd-consult.de
> FOSSGIS consulting , training , support and analysis
> Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
> Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130619/addb952c/attachment.html>
More information about the Qgis-community-team
