[Qgis-community-team] sphinx trouble
Otto Dassau
dassau at gbd-consult.de
Tue May 21 04:17:47 PDT 2013
Hi Matteo,
I built (post_translate) the italian 1.8 branch and it only creates the
folders _sources and docs. All other languages create much more:
_sources
docs
genindex.html
_images
_index.html
objects.inv
search.html
searchindex.js
_static
I don't have a clue yet, why this happens. But it is not a problem of sphinx
I guess.
Has anybody ever had such a problem?
Regards
Otto
Am Fri, 17 May 2013 10:05:40 +0200
schrieb matteo <matteo.ghetta at gmail.com>:
> Hi guys,
> as usually, before commit the translated files I build them with bash
> scripst(post_translate it, but I receive some errors, like;
> Exception occurred:
> File "/usr/lib/python2.7/dist-packages/sphinx/builders/html.py", line
> 419, in write_doc
> self.docwriter.write(doctree, destination)
> File "/usr/lib/python2.7/dist-packages/docutils/writers/__init__.py",
> line 77, in write
> self.translate()
> File "/usr/lib/python2.7/dist-packages/sphinx/writers/html.py", line
> 38, in translate
> self.document.walkabout(visitor)
> File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 173,
> in walkabout
> if child.walkabout(visitor):
> in walkabout
> in walkabout
> File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 165,
> in walkabout
> visitor.dispatch_visit(self)
> File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 1604,
> in dispatch_visit
> return method(node)
> File
> "/usr/lib/python2.7/dist-packages/docutils/writers/html4css1/__init__.py",
> line 957, in visit_footnote_reference
> href = '#' + node['refid']
> File "/usr/lib/python2.7/dist-packages/docutils/nodes.py", line 534,
> in __getitem__
> return self.attributes[key]
> KeyError: 'refid'
> What does it mean? Actually not for all the files I found the html. For
> example the entire folder working with vectors does not compare in the
> output.
> I attach the output lof file.
> Thanks
> Matteo
More information about the Qgis-community-team
