[Qgis-community-team] API documentation and a missing link
Otto Dassau
dassau at gbd-consult.de
Wed Nov 6 00:14:26 PST 2013
Am Wed, 06 Nov 2013 07:59:55 +0100
schrieb Richard Duivenvoorde <rdmailings at duif.net>:
> On 03-11-13 21:47, Borys Jurgiel wrote:
> > Hi,
> > At http://www.qgis.org/api you can see the Master's API and links to
> > some earlier 1.x API versions. However, the most important link to
> > http://www.qgis.org/api/2.0 is missing.
> > It may confuse plugin devs and make them writting 2.0 plugins not fully
> > compatible with the stable API. What about two big buttons: Stable |
> > Master? If I remember correctly, they were present in the 1.8 times and
> > it was working well.
> Hi Borys,
> I did a little search in codebase where this should be, and found this one:
> https://github.com/qgis/QGIS/blob/master/doc/index.dox
> apparently Jurgen already updated this template (in master).
> I've found a script in a cron job (Otto's?) on qgis server:
> /usr/local/sbin/update-api-doc
> which does 'something' with debian packages, but I'm not sure why it is
> not build yet.
> And/or how to fix those links in the older builds..
> Regards,
> Richard
I haven't created cron jobs for the api build. That's probably Jürgen in
combination with the debian packages.
Regards
Otto
More information about the Qgis-community-team
