[Qgis-community-team] error building docs locally
Otto Dassau
dassau at gbd-consult.de
Tue Oct 8 04:50:18 PDT 2013
Am Tue, 08 Oct 2013 13:36:28 +0200
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 08-10-13 11:35, Otto Dassau wrote:
> > Hi,
> > ok, I was too quick, here the next error after I did in my virtualenv:
> > pip install sphinx_bootstrap_theme
> > make html
> > Exception occurred:
> > File "/arbeit/github/QGIS-Documentation/source/conf.py", line 15, in
> > <module> import sphinx_bootstrap_theme
> > ImportError: No module named sphinx_bootstrap_theme
> > Is something missing in the QGIS-Documentation repo that is in
> > QGIS-Website?
> Hi Otto,
> sorry. Yes, I build the documentation in the same virtual environment as
> I do the QGIS-Website.
> Are you able to build the website?
> If so, it should also build the docs.
no the same error, but maybe I do something wrong? Is there a howto, if I
want to build it virtualenv?
Regards
Otto
More information about the Qgis-community-team
