[Qgis-community-team] QGIS Arabic status
Otto Dassau
dassau at gbd-consult.de
Sun Sep 8 12:58:37 PDT 2013
Am Sun, 08 Sep 2013 21:22:40 +0200
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 08-09-13 17:52, Otto Dassau wrote:
> > https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/documentation_guidelines/do_translations.rst
> > In general, if it is about the manual, we should take care, that manuals
> > are only translated in "translation" branches created for each qgis
> > version, after the english master branch is updated and tagged and
> > includes all new features of that version.
> > At the moment this is still manual_en_v1.8.
> Hi Otto,
> as we are busy with the website, and testing some different translation
> options, I was wondering something.
> So you say: if all went correct nobody is translating the master docs.
> So when normally do you pull over the .po files from the 1.8 branch to
> master?
> And as files and filenames can have changed, is this to be done/checked
> by hand?
> Richard
Hi Richard,
it would be possible to pull the translations to master again, if:
a) translation of a language is done within the translation branch
b) update of master for a version is ready, so before a new translation can
start
at the moment I prefered b), so it would all be don together.
And you are right. If filenames/files have changed, it will be necessary to
pull over the .po files manually. I don't see a better solution at the
moment.
Regards
Otto
More information about the Qgis-community-team
