[Qgis-community-team] second manual update round
Diethard Jansen
diethard.jansen at gmail.com
Sun Sep 22 22:21:41 PDT 2013
Regarding units for images:
I agree that the unit "em" should only be used for icons used in text. The
images should use pixels, I do believe in that case you do not have to add
a unit (px is the default).
During the latex to ReST conversion I sized the images with rather a lot of
effort using the "em" unit. We used the default sphinx theme at that time
and I just found out that it uses a font size of 16. I believe that when we
multiply most of the current images where the unit "em" is used with
sixteen the result should be great.
Maybe we should first try it with a plugin chapter (like the Evis plugin)
to see if it works.
Unfortunately today I have no time today to experiment with it.
regards,
Diethard
2013/9/22 Otto Dassau <dassau at gbd-consult.de>
> Hi Alexandre,
> Am Sat, 21 Sep 2013 23:31:06 +0100
> schrieb Alexandre Neto <senhor.neto at gmail.com>:
> > Hi there,
> > I'm also going to give a review on the screenshots an try to create new
> > versions for them. Is there a milestone for finishing it that I should
> know
> > about?
> thanks a lot. There is no milestone, but since QGIS 2.0 is out, I would say
> asap.
> > Also, is there a way in reStructuredText that, in the middle of the text,
> > instead of reference an image by its name, one could reference it by its
> > "Future number"?
> > Right now, in the text we ask the reader to see figure_symbology_3, but
> > the legend of the figure has something like "Figure 12.9: Example of
> custom
> > gradient color ramp with multiple stops".
> yes, I don't think we have a better solution for this right now - have we?
> > I have also a doubt, in reStructuredText, what unit is the "em" in
> > "':width: 12em"? Cause it would be nice to represent the images at a
> near
> > "resolution". We have a few images to big that are kind of pixelized, and
> > others to small to be able to read.
> Thanks for that question, I am not an expert here, but I found:
> Images with px dimensions are not resized when the user changes text size;
> images with em dimensions are resized. So if an image's size should be
> relative to the text size (a rare case), then use em. Otherwise px
> dimensions is fine.
> So I would also ask, does EM make sense for us?
> Regards
> Otto
> > Thanks
> > Alexandre Neto
> > On Sat, Sep 21, 2013 at 1:25 PM, Otto Dassau <dassau at gbd-consult.de>
> wrote:
> > > Hi,
> > > we almost went through the list of features that we wanted to update
> for
> > > the
> > > qgis 2.0 manual. The http://hub.qgis.org/wiki/quantum-gis/ManualTasks
> > > list of done, but I already saw, that there is still a lot of things we
> > > should have a look at again.
> > > My idea is now, that we start now with a second round. We go through
> each
> > > file and check, if something is missing or wrong. And when it is
> updated,
> > > we
> > > comment the disclaimer, so the file is done and ready for release.
> > > Here we should also check the figures and tell Alexandre, if a new
> figure
> > > is
> > > necessary.
> > > Thanks a lot to all contributors to the manual so far! And as usual,
> > > everybody is welcome to help us with this of course, so we have an
> > > updated manual that can be translated, soon.
> > > Regards
> > > Otto
> > > _______________________________________________
> > > Qgis-community-team mailing list for organizing community resources
> such
> > > as documentation, translation etc..
> > > Qgis-community-team at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Geoinformatik Büro Dassau - http://www.gbd-consult.de
> FOSSGIS consulting , training , support and analysis
> Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
> Tel: +49-(0)211-47468178 , Mobile: +49-(0)171-4687540
> Community Advisor - QGIS Project Steering Committee
> Qgis-community-team mailing list for organizing community resources such
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130923/7cbea848/attachment.html>
More information about the Qgis-community-team
