[Qgis-community-team] We need help updating the qgis user guide for version 2.2
    Richard Duivenvoorde
    richard at duif.net
    Tue Apr  8 00:38:43 PDT 2014
On 07-04-14 17:14, luca.casagrande at gmail.com wrote:
> Hello everybody,
> I almost completed the printer section, but I need to add some new
> icons (i.e. the Atlas Preview toolbar).
> I searched inside the resources/en/docs/common folder, but I couldn't find them.
Hi Luca,
can you give an example of an icon you are searching for? Eg by
providing a link from the online docs.
if you are busy in master version of QGIS-Documentation, images should
be here:
https://github.com/qgis/QGIS-Documentation/tree/master/resources/en/docs/user_manual
and then in the folder with the same name as your rst files are in.
Also note that the documentation use a lot of 'abbreviations' for
images, and those are defined in the conf.py file:
https://github.com/qgis/QGIS-Documentation/blob/master/source/conf.py#L193
Hope this helps,
Regards,
More information about the Qgis-community-team
