[Qgis-community-team] website/docs build apart on qgis2,	scp or rsync?
    Eduardo Gonzalez
    eg at gismood.com
    Sun Jun 15 03:53:18 PDT 2014
I just tested it on windows and worked nicely.
Thanks!
Eduardo
On Fri, Jun 13, 2014 at 5:31 PM, Richard Duivenvoorde <richard at duif.net>
wrote:
> On 10-06-14 12:59, Eduardo Gonzalez wrote:
> > I tested yesterday the paver for the GIS Documentation in Windows. It
> > almost worked but ended with:
> > "Build failed running pavement.html: Subprocess return code: 1"
> > I run the bootstrap without problems, then activated the virtualenv, and
> > finally run "paver.exe html".
> > The process copied the files but stoped immediately when running
> > "sphinx-intl.exe build -l en -c source/conf.py"... the file and path for
> > conf.py are correct...
> > Any pointers?
> > It would be great to be able to build the autonomally and this seems to
> > be a great way to do it!
> Hi Eduardo,
> this 'subprocess'-error is indeed not very helpfull.
> But today I added a bootstrap.py and a pavement.py file inot
> QGIS-Documentation master branch AND I tested this on a Windows7 machine
> I have here.
> I had I think the same problems and fixed them:
> 1) although it is supposed to work in a virtual environment, the
> python/module packages are a little mixed: when I try to run the last
> line in the error: sphinx.exe .... again on the command line it showed
> that it missed the jinja2 module. But trying to install it via 'pip
> install jinja2' it said it was already (globally installed). I removed
> the globally installed jinja2 and ran 'python bootstrap.py' again, and
> then jinja2 was available for the python in my virtual environment.
> 2) then there was an error in a jinja2-template which I fixed.
> So please try again, and report back (in a new thread I would say) if
> you still have errors.
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20140615/1e830f95/attachment.html>
More information about the Qgis-community-team
