[Qgis-community-team] Update translation for training
Yves Jacolin
yjacolin at free.fr
Sat Oct 11 11:48:34 PDT 2014
Le vendredi 10 octobre 2014, 10:23:23 Richard Duivenvoorde a écrit :
> On 10-10-14 09:21, Yves Jacolin wrote:
> > Hello,
> > Is it possible to get an update of the french translation of the training
> > manual? One of my workmet worked on this the last few weeks.
> > It is not urgent, of course :)
> Hi Yves,
> good that you note. Because we build every day now (look at other
> languages), so french should be build tonight too.
> (you can see in the footer of the doc frontpage when the last build was)
> but looking into the log I see there is an error only in french, so
> probably something in translation.
> If possible, can you have a look yourself, or somebody else? You have to
> build fr specifically, other languages seem ok.
> Or else I will try to have a look at it somewhere this weekend.
> The error from the log:
> reading sources... [ 23%]
> docs/training_manual/complete_analysis/raster_to_vector
> docs/training_manual/create_vector_data/actions
> Exception occurred:
> File "/usr/local/lib/python2.7/dist-packages/docutils/nodes.py", line
> 569, in __getitem__
> return self.children[key]
> IndexError: list index out of range
> The full traceback has been saved in /tmp/sphinx-err-4jpMF_.log, if you
> want to report the issue to the developers.
> Please also report this if it was a user error, so that a better error
> message can be provided next time.
> Either send bugs to the mailing list at
> <http://groups.google.com/group/sphinx-users/>,
> or report them in the tracker at
> <http://bitbucket.org/birkenfeld/sphinx/issues/>. Thanks!
> make[1]: *** [html] Error 1
> make: *** [full] Error 2
> make[1]: Leaving directory `/build'
> sending incremental file list
> Regards,
Richard,
I built fr documentation with sucess and I can't see any problem. Frontpage
for french translation shows that the last build was today around 17h00.
Did you work on this before me?
Thanks,
Y.
Yves Jacolin
More information about the Qgis-community-team
