[Qgis-community-team] Proposal to divide some pages in QGIS documentation
Yves Jacolin yjacolin at free.fr
Sat Jun 6 01:47:18 PDT 2015
Hello,
A big +1 for this. This is something we need to do some time. I remember did
it for the vector chapter last year.
I started to read and comment your PR. I need to build it before give more
comment but the PR seems ok for me except one small thing.
Rst engine will always start with a H1 header with the first symbol line found
in the rst file.
So each time you use ------------------ for instance, it will become a H1
header [1]. Same for [2] with  ==== line.
There is two small issues with this:
1. it is less readable for the same level of header, if sometime you use
"----" and another time "==="
2. if later you need to add another (sub)-sectionin [1], you should find
another symbol, so it will be probably one of ***, ====, +++ and they will
look a greater level (only to me?).
We should keep rst file human readable.
I will build your PR tomorrow if no one merge your PR before :)
Y.
[1] composer_items/composer_scale_bar.rst
[2] print_composer/first_steps.rst with
Le samedi 6 juin 2015, 01:22:26 DelazJ a écrit :
> Hi Folks,
> While reading QGIS documentation, there are some pages that leave me
> puzzled. You may have a look at Print Composer [1], vector properties
> dialog [2] pages.
> IMHO, these pages are too long. For the reader, scrolling can become
> tedious while looking for a precise information. Sure, the subject is wide
> and there is a lot of informations at these pages but I think that, because
> subject is wide, it can be splited into several pages, shorter, more
> precise and readable. As there are Previous/Next buttons, skipping sections
> while reading can easily be done.
> From writer side, I think that having short (and specialized) page helps us
> to quickly identify where there may be a lack of documentation, easily
> update or improve them...
> So, few days ago, I made a pull request [3] that splits Print Composer
> chapter into many pages, reorganizing sections and sequences.
> If you agree with the spliting principle of these chapters, can some
> documentation writers review it, amend it and let me know if it is ok? It's
> the first time I use rst files so it'd be nice if someone can review my PR
> before I begin spliting vector properties chapter.
> Regards,
> Harrissou
> [1]
> http://docs.qgis.org/2.8/fr/docs/user_manual/print_composer/print_composer.h
> tml [2]
> http://docs.qgis.org/2.8/fr/docs/user_manual/working_with_vector/vector_prop
> erties.html [3] https://github.com/qgis/QGIS-Documentation/pull/544/
Yves Jacolin
More information about the Qgis-community-team mailing list
