[Qgis-community-team] See the doc images at github (or not)
DelazJ
delazj at gmail.com
Tue Jun 9 01:29:38 PDT 2015
I have no skills on this but I think it'll indeed be very helpful to
display images while writing/updating documentation files in github
So, if it's easy to do and there is no side effect, +1 from me
2015-06-08 11:50 GMT+02:00 Richard Duivenvoorde <richard at duif.net>:
> Hi List,
> if you look at the rst files in our documentation repo, you will only
> see text, NOT the images:
> https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/training_manual/forestry/map_georeferencing.rst
> It appears that this is because we keep our images at /resource/en/...
> and copy them into /static during the build, to be able to have
> localized images....
> But after seeing the foss4glabs (markdown) sources in their github repo:
> https://github.com/FOSS4GAcademy/GST101FOSS4GLabs/blob/master/Module%205%20Lab/QGIS%202.8/Module%205%20Lab.md
> I wondered if it would also be possible that we showed our images in the
> rst-view of github.
> It indeed is easy: just copy the english (en) image directory to a
> directoy 'static' and all images which are referenced like:
> .. image:: /static/training_manual/forestry/f_1.png
> are viewable now at github (this is a temporary fork to be able to
> fiddle a little with this, note only foresty images are copied):
> https://github.com/rduivenvoorde/QGIS-Documentation/blob/master/source/docs/training_manual/forestry/map_georeferencing.rst
> as you can see, it is only plain images you see, the images which are
> 'shortcuts' from conf.py you will not see.
> But I think it is valuable to see the images immediately in Github, it
> makes spotting 'old' images much easier for doc writers/editors.
> The only reason the images currently are not in '/static' dir/tree is
> that we want the building process to be able to FIRST copy the
> english(original) images in the /static dir during build and THEN copy
> (optional) localized images over it during a localized build.
> But there is not reason to not put the english images already in the
> '/static' dir (so moving them from /resource/en/... to /static) and
> change some steps in the build proces
> So please comment on the following proposal:
> - we move the resource/en directory to /static
> - change some steps in the build scripts
> - we could do the same for the website...
> Comments?
> Regards,
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20150609/3a3954c6/attachment.html>
More information about the Qgis-community-team
