[Qgis-community-team] 2.12 documentation
Richard Duivenvoorde richard at duif.net
Mon Oct 5 05:51:59 PDT 2015
On 05-10-15 14:42, DelazJ wrote:
> Hi,
> Indeed, 2.10 is a basis to document 2.12 features.
> I may misunderstand but what do you mean by" releasing both manuals"?
> Does it mean a 2.10 manual will also be pushed to transifex for
> translation? Does it worth publishing and translating a manual since
> most of users will either stay on 2.8-ltr or move to 2.12?
> Note that there's no branch for 2.10 yet.
Mmm, you are right, we did not create a branch for 2.10 because there is
not a separate build for 2.10...
What we normally did: AFTER the QGIS release x we update the
documentation so it covered version x and then branched and created a
http://docs.qgis.org/x version.
With 2.10 apparently there has been no work on the docs, OR I just
simply forgot to branch... :-(
Anyway, let's do this for 2.12 then:
- update master untill it is up to date with 2.12 features
- AFTER QGIS 2.12 release we will branch a 2.12 and build ONLY english
version and make it online available
- next LTR: 2.14 we will do the same, but THEN we will also upload the
sources to Transifex again to have the LTR docs translatable.
Clear enough?
Regards,
Richard
More information about the Qgis-community-team mailing list
