[Qgis-community-team] Doc writing: simpler writing and styling
Otto Dassau
otto at qgis.org
Sun Jan 17 12:17:44 PST 2016
Hi Richard,
Am Sun, 17 Jan 2016 20:04:31 +0100
schrieb Richard Duivenvoorde <richard at duif.net>:
> On 17-01-16 10:17, Otto Dassau wrote:
> > Hi Alexandre,
> > thanks a lot for your help! Since feature freeze already started, you
> > could start updating existing figures, if necessary, I guess. So you
> > have about 6 weeks from now...
> Hi Otto, Alexandre,
> I'm also eager to have a good updated 2.14 manual shortly after the 2.14
> release.
> I see there is already a wiki page:
> http://hub.qgis.org/wiki/quantum-gis/ManualTasks
> We use that one as central communication point (and this list)?
no, as Yves just wrote it would probably be the best, if we only use the
ManualTasks to see, if all FEATUREs are integrated as issues in github. And
as far as I understand it should automatically be the case.
Then we would use the github issues to update the manual and this list.
> So do we agree to:
> - have the images let relative url's
> - remove all the :guilabel: :menuselection: and other directives (but
> keep the single quotes!)
> - get rid of all/most of the image/icon substitutions (needed for inline
> images) from source.conf and put them in the source file where they are
> used
I would agree, because it would make the update easier for contributors I
guess.
> Only discussion I would like to have:
> - besides putting the images in the rst-directories, we also could put
> them (in the same structure as they are now in a 'static' directory).
> This means that all paths become like
> ../../../..static/docs/user_manual/working_with_vector/ or so... Mmm,
> writing this down, I think directories in individual src dir's is best :-)
it should be as simple as possible to define new figures.
> - is is still usefull to have the 'Operating System' icons around (that
> is the little Mac, Linux and Windows icons) for screenies OR when the
> instructions differ...
maybe we don't need them anymore
> - at this moment I'm not aware of any language really creating
> translated images(! please correct me if I'm wrong). So I think I remove
> this infrastructure as it can make building and scripts simpler
me neither, German did in the past but stopped.
> - we/I have still test what happens with the translations of sentences
> which we remove directives and substitutions from (I hope the old
> translations will be available in the glossary....)
I would assume that old translation will appear as translation suggestion in
transifex. But i am not sure.
> If nobody objects, I'll start (in one commit) to do this page:
> https://github.com/qgis/QGIS-Documentation/blob/master_github_e/source/docs/user_manual/working_with_vector/vector_properties.rst
> So everybody can see what it looks like online in pdf and in Github
fine for me.
Thanks
Otto
> Regards,
> ps in parallel I hope te replace the templates for the new docs...
More information about the Qgis-community-team
