[Qgis-community-team] Doc images and github
Yves Jacolin
yjacolin at free.fr
Wed Jan 27 01:11:09 PST 2016
Richard,
I am not a big contributor. But I am ok with option 2 as well.
Y.
On Wednesday, January 27, 2016 10:00:39 Richard Duivenvoorde wrote:
> Others?
> Else I think I'll start to do all whole rst files in working_with_vector
> directory and commit in one go. So it can be reversed if we hit problems.
> @Alexandre: putting ALL rst file in one dir would indeed help, but I
> think we need the structure to be able to eventually build partial
> documentation sets.
> We could put the substitutions maybe in the index.rst files in the
> directory where the images dir also is, but that would also scatter the
> substitutions. Then I think having them in de file where you need them
> is easiest, also because then you can move around the rst file in the
> directory structure without fixing relative paths... (as long as you
> copy the images also to the right place off course :-) ).
> Anyway: proceed?
> Richard
> On 26-01-16 14:08, Otto Dassau wrote:
> > Hi Richard,
> > thanks a lot for this grep/count. In this case I would vote for option 2:
> > ..."define figures locally in the rst file where you use them. This has as
> > drawback that very often used inline images (like the checkbox) are
> > defined
> > + image copied very often. BUT the nice thing about it is that IF you
> > define them in the rst file, Github is able to resolve those SO they show
> > up as inline images there."
> > Regards
> > Otto
> > Am Mon, 25 Jan 2016 21:34:51 +0100
> > schrieb Richard Duivenvoorde <richard at duif.net>:
> >> On 25-01-16 11:06, Alexandre Neto wrote:
> >>> Not an easy choice... I'm not very fond of duplicating substitutions
> >>> images as I believe it will lead to pages with different icons because
> >>> someone just update one place. Maybe it would be possible to have a
> >>> common place with all images and some kind of script to copy the icons
> >>> to a child forder near the rst?
> >> FYI, I did a quick grep/count on all substitutions over ALL docs (so not
> >> only manual).
> >> While I agree with your point... there are not so many images used > 2
> >> times...
> >> |nix| 45
> >> |win| 15
> >> |osx| 9
> >> |action| 2
> >> |analysis| 1
> >> |attributes| 4
> >> |basic_statistics| 2
> >> |browsebutton| 10
> >> |buffer| 2
> >> |calendarwidget| 0
> >> |checkbox| 41
> >> |checkbox_checked| 1
> >> |checkbox_unchecked| 1
> >> |check_geometry| 2
> >> |centroids| 2
> >> |clip| 2
> >> |color| 0
> >> |colormap| 0
> >> |columnview| 0
> >> |combobox| 0
> >> |commandlinkbutton| 0
> >> |convex_hull| 2
> >> |coordinate_capture| 2
> >> |copyright_label| 2
> >> |CRS| 1
> >> |create_gpx| 1
> >> |dateedit| 0
> >> |datetimeedit| 0
> >> |dbmanager| 2
> >> |define_projection| 2
> >> |delaunay| 2
> >> |delimited_text| 2
> >> |dem_analysis| 1
> >> |diagram| 2
> >> |dial| 0
> >> |dialogbuttonbox| 0
> >> |difference| 2
> >> |digitising| 0
> >> |dissolve| 2
> >> |dockwidget| 0
> >> |doublespinbox| 0
> >> |dxf2shp_converter| 3
> >> |edit| 4
> >> |eliminate| 1
> >> |event_browser| 1
> >> |event_id| 3
> >> |evis_connect| 2
> >> |evis_file| 2
> >> |export_geometry| 2
> >> |export_projection| 1
> >> |extract_nodes| 2
> >> |fontcombobox| 0
> >> |frame| 0
> >> |ftools| 2
> >> |fullCumulativeStretch| 1
> >> |FullHistogramStretch| 1
> >> |gdal| 1
> >> |gdal_about| 0
> >> |gdal_assign_projection| 1
> >> |gdal_contour| 1
> >> |gdal_dem| 1
> >> |gdal_edit| 0
> >> |gdal_extract_projection| 1
> >> |gdal_fillnodata| 1
> >> |gdal_grid| 1
> >> |gdal_merge| 1
> >> |gdal_nearblack| 1
> >> |gdal_polygonize| 1
> >> |gdal_proximity| 1
> >> |gdal_raster-clip| 1
> >> |gdal_raster-overview| 1
> >> |gdal_raster-paletted| 0
> >> |gdal_raster-rgb| 1
> >> |gdal_rasterize| 1
> >> |gdal_reset| 0
> >> |gdal_sieve| 1
> >> |gdal_tileindex| 1
> >> |gdal_tooltip| 0
> >> |gdal_translate| 1
> >> |gdal_vrt| 1
> >> |gdal_warp| 1
> >> |general| 2
> >> |gentlelogo| 10
> >> |geographic| 3
> >> |geometry| 1
> >> |geometrychecker| 2
> >> |geometrysnapper| 2
> >> |geoprocessing| 2
> >> |georeferencer| 1
> >> |geRasterometry| 0
> >> |gps_importer| 2
> >> |gpstrack_barchart| 2
> >> |gpstrack_polarchart| 2
> >> |graphicsview| 0
> >> |grass| 2
> >> |grass_close_mapset| 2
> >> |grass_location| 1
> >> |grass_new_mapset| 3
> >> |grass_open_mapset| 2
> >> |grass_region| 2
> >> |grass_set_region| 1
> >> |grass_region_edit| 1
> >> |grass_tools| 3
> >> |groupbox| 0
> >> |groupboxcollapsible| 0
> >> |heatmap| 4
> >> |histogram| 0
> >> |hscrollbar| 0
> >> |hslider| 0
> >> |hsplit| 0
> >> |iconAboutConsole| 0
> >> |iconClassBrowserConsole| 0
> >> |iconClassConsole| 0
> >> |iconClassTreeWidgetConsole| 0
> >> |iconClearConsole| 0
> >> |iconCloseTabEditorConsole| 0
> >> |iconCodepadConsole| 0
> >> |iconCommentEditorConsole| 0
> >> |iconCopyEditorConsole| 0
> >> |iconCutEditorConsole| 0
> >> |iconFileTabsMenuConsole| 0
> >> |iconFunctionTreeWidgetConsole| 0
> >> |iconHelpConsole| 0
> >> |iconHideToolConsole| 0
> >> |iconIfaceConsole| 0
> >> |iconMethodTreeWidgetConsole| 0
> >> |iconNewTabEditorConsole| 0
> >> |iconOpenConsole| 0
> >> |iconPasteEditorConsole| 0
> >> |iconQtCoreConsole| 0
> >> |iconQtGuiConsole| 0
> >> |iconRestoreTabsConsole| 0
> >> |iconRunConsole| 0
> >> |iconRunScriptConsole| 0
> >> |iconSaveAsConsole| 0
> >> |iconSaveConsole| 0
> >> |iconScriptConsole| 0
> >> |iconSettingsConsole| 0
> >> |icon_newgpx| 1
> >> |icon_dbmanager| 3
> >> |icon_zonal_statistics| 1
> >> |import_gpx| 1
> >> |inputtext| 2
> >> |interpolation| 2
> >> |intersect| 2
> >> |intersections| 2
> >> |join| 2
> >> |join_location| 2
> >> |labels| 1
> >> |layer_extent| 2
> >> |locale| 1
> >> |locked| 2
> >> |mAction| 3
> >> |mActionAdd| 1
> >> |mActionAddAllToOverview| 2
> >> |mActionAddArrow| 3
> >> |mActionAddBasicShape| 3
> >> |mActionAddDelimitedTextLayer| 0
> >> |mActionAddGCPPoint| 1
> >> |mActionAddHtml| 2
> >> |mActionAddImage| 3
> >> |mActionAddLayer| 1
> >> |mActionAddLegend| 5
> >> |mActionAddMap| 6
> >> |mActionAddMssqlLayer| 2
> >> |mActionAddNonDbLayer| 1
> >> |mActionAddOgrLayer| 4
> >> |mActionAddOracleLayer| 1
> >> |mActionAddPart| 4
> >> |mActionAddPostgisLayer| 2
> >> |mActionAddRasterLayer| 7
> >> |mActionAddRing| 4
> >> |mActionAddSpatiaLiteLayer| 3
> >> |mActionAddWmsLayer| 3
> >> |mActionAlignBottom| 2
> >> |mActionAlignHCenter| 2
> >> |mActionAlignLeft| 4
> >> |mActionAlignRight| 2
> >> |mActionAlignTop| 2
> >> |mActionAlignVCenter| 2
> >> |mActionAllEdits| 2
> >> |mActionAnnotation| 2
> >> |mActionArrowDown| 1
> >> |mActionArrowLeft| 0
> >> |mActionArrowRight| 1
> >> |mActionArrowUp| 0
> >> |mActionAtlasFirst| 2
> >> |mActionAtlasLast| 2
> >> |mActionAtlasNext| 2
> >> |mActionAtlasPrev| 2
> >> |mActionAtlasSettings| 1
> >> |mActionCancelEdits| 1
> >> |mActionCalculateField| 6
> >> |mActionCaptureBoundary| 1
> >> |mActionCaptureCentroid| 1
> >> |mActionCaptureLine| 4
> >> |mActionCapturePoint| 4
> >> |mActionCapturePolygon| 5
> >> |mActionChangeLabelProperties| 2
> >> |mActionCheckQgisVersion| 2
> >> |mActionCollapseTree| 2
> >> |mActionComposerManager| 4
> >> |mActionContextHelp| 1
> >> |mActionCopySelected| 3
> >> |mActionCustomProjection| 3
> >> |mActionDeleteAttribute| 3
> >> |mActionDeleteGCPPoint| 1
> >> |mActionDeletePart| 4
> >> |mActionDeleteRing| 4
> >> |mActionDeleteSelected| 4
> >> |mActionDeselectAll| 2
> >> |mActionDraw| 5
> >> |mActionDupComposer| 2
> >> |mActionDuplicateLayer| 1
> >> |mActionEditCopy| 5
> >> |mActionEditCut| 4
> >> |mActionEditPaste| 4
> >> |mActionExpandNewTree| 2
> >> |mActionExpandTree| 2
> >> |mActionExportMapServer| 1
> >> |mActionFileExit| 2
> >> |mActionFileNew| 3
> >> |mActionFileOpen| 6
> >> |mActionFilePrint| 5
> >> |mActionFileSave| 6
> >> |mActionFileSaveAs| 9
> >> |mActionFillRing| 2
> >> |mActionFilter| 1
> >> |mActionFolder| 2
> >> |mActionFormAnnotation| 2
> >> |mActionFullHistogramStretch| 1
> >> |mActionGDALScript| 2
> >> |mActionGroupItems| 2
> >> |mActionHelpAbout| 2
> >> |mActionHelpContents| 2
> >> |mActionHelpSponsors| 2
> >> |mActionHideAllLayers| 2
> >> |mActionmIconExpressionEditorOpen| 1
> >> |mActionIdentify| 6
> >> |mActionInOverview| 2
> >> |mActionInvertSelection| 2
> >> |mActionLabel| 4
> >> |mActionLabeling| 4
> >> |mActionLink| 1
> >> |mActionLinkGeorefToQGis| 2
> >> |mActionLinkQGisToGeoref| 2
> >> |mActionLoadGCPpoints| 1
> >> |mActionLocalHistogramStretch| 1
> >> |mActionLowerItems| 2
> >> |mActionMapTips| 3
> >> |mActionMeasure| 3
> >> |mActionMeasureAngle| 2
> >> |mActionMeasureArea| 2
> >> |mActionMergeFeatAttributes| 3
> >> |mActionMergeFeatures| 3
> >> |mActionMoveFeature| 4
> >> |mActionMoveGCPPoint| 1
> >> |mActionMoveItemContent| 4
> >> |mActionMoveItemsToBottom| 2
> >> |mActionMoveItemsToTop| 2
> >> |mActionMoveLabel| 2
> >> |mActionNewAttribute| 3
> >> |mActionNewBookmark| 2
> >> |mActionNewComposer| 6
> >> |mActionNewSpatiaLiteLayer| 2
> >> |mActionNewVectorLayer| 3
> >> |mActionNodeTool| 4
> >> |mActionOffsetCurve| 4
> >> |mActionOpenRaster| 0
> >> |mActionOpenTable| 7
> >> |mActionOptions| 9
> >> |mActionPan| 6
> >> |mActionPinLabels| 1
> >> |mActionProjectProperties| 3
> >> |mActionPropertyItem| 2
> >> |mActionQgisHomePage| 2
> >> |mActionRaiseItems| 3
> >> |mActionRedo| 5
> >> |mActionRemove| 1
> >> |mActionRemoveAllFromOverview| 1
> >> |mActionRemoveLayer| 3
> >> |mActionReshape| 4
> >> |mActionRollbackEdits| 1
> >> |mActionRotateFeature| 1
> >> |mActionRotateLabel| 1
> >> |mActionRotatePointSymbols| 3
> >> |mActionSaveAsPDF| 4
> >> |mActionSaveAsSVG| 5
> >> |mActionSaveEdits| 3
> >> |mActionSaveGCPpointsAs| 1
> >> |mActionSaveMapAsImage| 6
> >> |mActionScaleBar| 4
> >> |mActionSelect| 10
> >> |mActionSelectFreehand| 2
> >> |mActionSelectPan| 1
> >> |mActionSelectPolygon| 2
> >> |mActionSelectRadius| 2
> >> |mActionSelectRectangle| 2
> >> |mActionSelectedToTop| 2
> >> |mActionShowAllLayers| 3
> >> |mActionShowBookmarks| 2
> >> |mActionShowHideLabels| 1
> >> |mActionShowPinnedLabels| 1
> >> |mActionShowPluginManager| 6
> >> |mActionShowPresets| 3
> >> |mActionSignMinus| 3
> >> |mActionSignPlus| 6
> >> |mActionSimplify| 4
> >> |mActionSplitFeatures| 5
> >> |mActionSplitParts| 3
> >> |mActionStartGeoref| 2
> >> |mActionTextAnnotation| 2
> >> |mActionToggleEditing| 6
> >> |mActionTouch| 1
> >> |mActionTransformSettings| 2
> >> |mActionUndo| 5
> >> |mActionUnGroupItems| 1
> >> |mActionUnlink| 1
> >> |mActionUnselectAttributes| 1
> >> |mActionWhatsThis| 2
> >> |mActionZoomActual| 3
> >> |mActionZoomFullExtent| 5
> >> |mActionZoomIn| 8
> >> |mActionZoomLast| 3
> >> |mActionZoomNext| 3
> >> |mActionZoomOut| 8
> >> |mActionZoomToLayer| 4
> >> |mActionZoomToSelected| 4
> >> |management| 1
> >> |mapserver_export| 1
> >> |matrix| 2
> >> |mean| 2
> >> |merge_shapes| 2
> >> |metadata| 2
> >> |metasearch| 2
> >> |mGeorefRun| 1
> >> |mIconAtlas| 3
> >> |mIconColorBox| 2
> >> |mIconColorPicker| 2
> >> |mIconColorSwatches| 2
> >> |mIconColorWheel| 2
> >> |mIconDataDefine| 6
> >> |mIconExpression| 1
> >> |mIconExpressionSelect| 4
> >> |mIconImport| 1
> >> |mIconLock| 2
> >> |mIconNew| 2
> >> |mIconProjectionDisabled| 2
> >> |mIconProjectionEnabled| 3
> >> |mIconRasterGroup| 1
> >> |mIconRasterLink| 1
> >> |mIconStopRendering| 1
> >> |mIconZip| 1
> >> |multi_to_single| 2
> >> |neighbor| 2
> >> |north_arrow| 2
> >> |offline_editing_copy| 3
> >> |offline_editing_sync| 2
> >> |oracle_raster| 3
> >> |osm_addRelation| 1
> >> |osm_createLine| 1
> >> |osm_createPoint| 1
> >> |osm_createPolygon| 1
> >> |osm_createRelation| 1
> >> |osm_download| 1
> >> |osm_editRelation| 1
> >> |osm_featureManager| 1
> >> |osm_generateTags| 1
> >> |osm_identify| 1
> >> |osm_import| 1
> >> |osm_load| 1
> >> |osm_move| 1
> >> |osm_questionMark| 1
> >> |osm_removeFeat| 1
> >> |osm_removeTag| 0
> >> |osm_save| 1
> >> |osm_upload| 0
> >> |PanToSelected| 3
> >> |pencil| 2
> >> |plugin| 3
> >> |plugin_installed| 1
> >> |plugin_installer| 2
> >> |plugin_upgrade| 1
> >> |proc_commander| 1
> >> |proc_history| 1
> >> |proc_model| 1
> >> |proc_option| 1
> >> |proc_result| 1
> >> |proc_toolbox| 1
> >> |qgissplash| 0
> >> |radiobuttonon| 15
> >> |radiobuttonoff| 10
> >> |random_points| 2
> >> |random_selection| 2
> >> |raster-info| 3
> >> |raster-interpolate| 2
> >> |raster-stats| 2
> >> |raster_terrain| 2
> >> |regular_points| 2
> >> |RemoveAllOVerview| 2
> >> |roadgraph| 1
> >> |sampling| 1
> >> |scale_bar| 2
> >> |selectcolor| 3
> >> |selectcreatelayer| 2
> >> |selectnumber| 9
> >> |selectstring| 17
> >> |selectesubsetlayer| 2
> >> |select_location| 2
> >> |ShowRasterCalculator| 1
> >> |single_to_multi| 2
> >> |slider| 6
> >> |spatialquery| 3
> >> |spiticon| 2
> >> |split_layer| 2
> >> |sub_selection| 2
> >> |sum_lines| 2
> >> |sum_points| 2
> >> |sym_difference| 2
> >> |symbology| 1
> >> |simplify| 2
> >> |tab| 1
> >> |to_lines| 2
> >> |topologychecker| 2
> >> |tracking| 2
> >> |transformed| 1
> >> |union| 2
> >> |unique| 2
> >> |unlocked| 2
> >> |user| 1
> >> |vector_grid| 2
> >> |wcs| 1
> >> |wfs| 4
> >> _______________________________________________
> >> Qgis-community-team mailing list for organizing community resources such
> >> as documentation, translation etc.. Qgis-community-team at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Qgis-community-team mailing list for organizing community resources such as
More information about the Qgis-community-team
