[Qgis-community-team] [Qgis-developer] Moving the install instructions to a more sexy, visible, coherent and translatable page in qgis.org
Richard Duivenvoorde rdmailings at duif.net
Tue May 17 10:50:33 PDT 2016
Personally I'm ok with moving to rst / docs with the following arguments:
- it can be translated
- it is easier searchable (google)
- it will hopefully kept uptodate by more people because they try the
instructions and report back
Only reason NOT doing it was because in an earlier hackfest (when I
already put them to rst), I thought Juergen told me something about
scripts which kept the files uptodate.
IF only the apt-get lines are truely updated in that way, I'm ok with
moving.
Plz others speak out.
Regards,
Richard
On 17-05-16 11:46, DelazJ wrote:
> Hi all,
> So, is any decision taken about this? Does it seem feasible?
> Regards,
> Harrissou
> 2016-04-25 17:19 GMT+02:00 Jürgen E. <jef at norbit.de <mailto:jef at norbit.de>>:
>     Hi Richard,
>     On Sat, 23. Apr 2016 at 16:53:46 +0200, Richard Duivenvoorde wrote:
>     > @jef: maybe you can elaborate a little more on this?
>     You're probably referring to scripts/scandeps.pl
>     <http://scandeps.pl>.  That updates the apt-get
>     install lines in doc/linux.t2t from the packaging files in debian/
>     But that's about it.  I'm not sure those are actually necessary -
>     I'd try to
>     keep specific versions from the descriptions if possible.  As that's
>     what tend
>     to outdate quickly and point to the packaging files instead, because
>     those are
>     actually used and maintained.
>     BTW I for instance don't go through manually setting up the build
>     with cmake
>     for development, but produce packages once (or sometimes even kill
>     the build
>     half way) and keep using that build directory for development (both
>     on linux
>     and windows).
>     On Debian that complains about what dependencies are missing anyway
>     - so having
>     the apt-get install list above isn't necessary.  You could also just
>     add the
>     nightly repository for the distribution you target and run apt-get
>     build-dep
>     qgis and achieve the same.
>     Jürgen
>     Jürgen E. Fischer           norBIT GmbH             Tel.
>     +49-4931-918175-31 <tel:%2B49-4931-918175-31>
>     Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>     +49-4931-918175-50 <tel:%2B49-4931-918175-50>
>     Software Engineer           D-26506 Norden
>      http://www.norbit.de
>     QGIS release manager (PSC)  Germany                    IRC: jef on
>     FreeNode
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
