[Qgis-community-team] Websites moved + https
    Andreas Neumann
    a.neumann at carto.net
    Sun Dec  3 09:43:56 PST 2017
Hi Richard,
The website feels very snappy currently.
Thanks for your work!
Andreas
On 03.12.2017 13:13, Richard Duivenvoorde wrote:
> Hi,
> We moved
> qgis.org/www.qgis.org/version.qgis.org
> and
> doc.qgis.org
> from the old osgeo server to qgis2, the Hetzner server where
> plugins.qgis.org iss also running.
> FYI issues.qgis.org is running on qgis3
> We also tested/used Letsencrypt certificate because the Globalsign cert
> was almost expired.
> See:
> https://qgis.org
> https://plugins.qgis.org
> (all let's encrypt now)
> I thought to disable http traffic for both, so
> http://qgis.org is redirected to https:/qgis.org
> (the standard Letsencrypt way, with some rewrite rules)
> I also did that for plugins.qgis.org, but then people started to have
> issues with installing plugins, so I reverted that for now, and will
> report an issue around that.
> Documentation is not yet https, not sure about that.
> To me qgis.org/api is now much much faster \o/
> IF you have troubles or see problems, please report back to admin at qgis.org
> TODO:
> - bring letsencrypt to issues.qgis.org
> - fix plugins.qgis.org https problem
> - bring test.qgis.org to qgis2
> - check github hooks
> Regards,
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
