[Qgis-community-team] Master is now only compatible with plugins for 3.0
Borys Jurgiel
lists at borysjurgiel.pl
Wed Jan 3 09:42:05 PST 2018
Hi Lists,
Please note a small change in plugin compatibility behavior:
>From now, 2.99 is explicitly compatible with plugins for 3.0,
same as 3.99 will be compatible with 4.0 plugins etc.
So you no longer need to declare the bizarre 2.99 - 3.99 compatibility range
for your plugins. Just set QgisMinimumVersion to 3.0 in order to make them
compatible with QGIS 2.99 - 3.98.
See the change and a short discussion: https://github.com/qgis/QGIS/pull/5904/
If you definitely disagree but you missed the discussion, feel free to raise
it now, while we still can revert it.
Regards,
Borys
More information about the Qgis-community-team
