[Qgis-community-team] Move old core plugins documentation and port it to Processing
delazj at gmail.com delazj at gmail.com
Wed Jan 31 18:56:01 PST 2018
Hi Matteo,
Le 31 janv. 2018 5:55 PM, matteo <matteo.ghetta at gmail.com> a écrit :
> Hi guys,
> some old QGIS 2.x plugins have been totally ported into Processing:
> * Heatmap
> * Interpolation
> * Zonal statistics
> and are not longer available in the plugin menu. While
> * Gdal Tools
> have been ported into Processing but they still have their menu.
> I think we have to move (and adapt of course) the docs of the first
> group into the Processing documentation and remove from the plugin
> index. For The heatmap there is also a nice example that it's worth to
> include and don't loose.
See https://github.com/qgis/QGIS-Documentation/pull/1806, the eldest open pull request. I never merged it because i expected that there are some details a doc writer would like to reuse one day. The day has come?
> For gdal tools I'd say to let them where they are: even if this could
> seem a duplication of documents, actually they are available in 2
> different places.
Here, I disagree with you:
- duplicates should be avoided. When algs get updates, it just double the work if the committer does not forget one of the page (in which case you end up with two different descriptions -really bad). Better take advantage of cross link rather than duplicating contents.
- GdalTools (Raster menu) is not different from fTools (Vector menu), hence they should be handled the same way. While vector has been placed at the top of Processing chapter (http://docs.qgis.org/testing/en/docs/user_manual/processing/index.html%E2%80%A6) I don't feel it makes sense there and had opened an issue report at https://github.com/qgis/QGIS-Documentation/issues/2123. Inputs are welcome.
Regards,
Harrissou
> index of the existing documentation here:
> https://docs.qgis.org/testing/en/docs/user_manual/plugins/
> Ideas?
> Cheers
> Matteo
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
