[Qgis-community-team] Question about identifying sliver polygons and assign each to the neighboring polygon that shares the same attribute value such as block ID
Fangwu Wei fwei15 at asu.edu
Fri Jun 1 12:14:39 PDT 2018
Dear QGIS fellows,
I know there's a feature in QGIS to eliminate sliver polygons and it can
also be implemented in standalone script. It seems like a blackbox to get
the results directly. Is there a way in standalone script to identify
(extract) sliver polygons? Also, can I use other parameters (e.g. the
neighboring polygon that shares the same attribute value such as block ID)
not the ones given in QGIS to assign slivers?
Thanks!
FW
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20180601/0343cb5a/attachment.html>
More information about the Qgis-community-team mailing list
