[Qgis-community-team] using python virtualenv for installing depenncies of repository QGIS-Documentation
Richard Duivenvoorde
rdmailings at duif.net
Wed Feb 20 07:42:19 PST 2019
I did the following to get a building environment
Note: I'm on Linux here:
cd /tmp (or whatever dir you are going to use)
git clone https://github.com/qgis/QGIS-Documentation.git
cd QGIS-Documentation
virtualenv -p python3 venv
source venv/bin/activate
pip install -r REQUIREMENTS.txt
make html
In master I then get:
writing output... [ 24%]
docs/training_manual/database_concepts/data_model
Exception occurred:
File
"/tmp/QGIS-Documentation/venv/lib/python3.7/site-packages/pygments/lexer.py",
line 191, in streamer
for _, t, v in self.get_tokens_unprocessed(text):
RuntimeError: generator raised StopIteration
The full traceback has been saved in /tmp/sphinx-err-dpwwe5au.log, if
you want to report the issue to the developers.
Please also report this if it was a user error, so that a better error
message can be provided next time.
A bug report can be filed in the tracker at
<https://github.com/sphinx-doc/sphinx/issues>. Thanks!
make: *** [Makefile:73: html] Error 1
I also get this error:
Warning, treated as error:
intersphinx inventory 'https://qgis.org/pyqgis/3.4/objects.inv' not
fetchable due to <class 'requests.exceptions.ProxyError'>:
HTTPSConnectionPool(host='qgis.org', port=443): Max retries exceeded
with url: /pyqgis/3.4/objects.inv (Caused by ProxyError('Cannot connect
to proxy.',
NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object
at 0x7ff955a647b8>: Failed to establish a new connection: [Errno -2]
Name or service not known',)))
Makefile:69: recipe for target 'html' failed
So my feeling is that the intersphinx mapper:
source/conf.py
line 69:
intersphinx_mapping = {'pyqgis_api': ('https://qgis.org/pyqgis/3.4/', None)}
is not happy: so I would comment out that line for now
If still to working, let me know
Regards,
Richard
On 20/02/2019 16.18, Richard Duivenvoorde wrote:
> On 20/02/2019 14.43, Larissa Junek wrote:
>> Hello,
>> I'm in charge of writing the user manual the next year and wanted to say
>> hello!
>> I installed a production branch after the instructions on
>> https://docs.qgis.org/testing/en/docs/documentation_guidelines/first_contribution.html
>> I write the documentation using a python virtualenv.
>> My problem is, that using the <pip install -r REQUIREMENTS.txt> command
>> after creating my production branch doesn't build the dependencies
>> correctly.
>> Error message:
>> <Command "python setup.py egg info" failed with error code in
>> /tmp/pip-build- h2lvmza/transiflex-client/>
>> Is there somebody who can help me?
> Hi Larissa,
> I'm happy to help you, what about a skype call?
> I'll sent you my skype handle in a private msg
> Regards,
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
