[Qgis-community-team] [Qgis-user] training manual QGIS 3
Alexandre Neto
senhor.neto at gmail.com
Mon Jan 7 06:39:23 PST 2019
Some of those changes are quite small. Would you be interested in learning
how to fix it yourself?
A seg, 7/01/2019, 14:37, Alexandre Neto <senhor.neto at gmail.com> escreveu:
> Actually, someone already did it. Thanks!!
>> I can do it.
>> A seg, 7/01/2019, 13:43, Janneke van Dijk <janneke.qgis at gmail.com>
>> escreveu:
>>> I've registered all that I've noticed, I just didn't manage to tag them
>>> with training manual. Should I do that or is that someone else who adds the
>>> labels?
>>> Janneke
>>> On 07/01/2019 00:42, Alexandre Neto wrote:
>>> Better duplicated issues than missing ones . So please report whatever
>>> you feel that is a bug, or a possible improvement. That way we won't forget.
>>> Thanks!
>>> A dom, 6/01/2019, 10:07, Janneke van Dijk <janneke.qgis at gmail.com>
>>> escreveu:
>>>> Hi Harrissou,
>>>> Getting ready to at least list my observations. Do I understand it
>>>> correctly that whatever is not mentioned in [2] is not being addressed?
>>>> Quite a few of my remarks will also related to updating screenshots, which
>>>> I think has also been mentioned as a general issue somewhere - should I
>>>> still list them separately?
>>>> Thanks for your assistance,
>>>> Janneke
>>>> On 05/01/2019 13:33, DelazJ wrote:
>>>> Hi Janneke,
>>>> Thanks for your tests. And indeed the training manual update is a work
>>>> in progress and maybe could you publish your remarks as issue reports in
>>>> the doc repository [0] so that we took them into consideration as we go.
>>>> You are right about the missing data, there was a pull request [1] to
>>>> integrate these data we forgot to merge. Done now! Download the dataset
>>>> again, please.
>>>> Note that we are reviewing initial lessons and have some pending
>>>> updates for both lessons [2] and corresponding data [3]. Tests and
>>>> feedbacks are more than welcome. Thanks!
>>>> [0] https://github.com/qgis/QGIS-Documentations/issues
>>>> [1] https://github.com/qgis/QGIS-Training-Data/pull/15
>>>> [2]
>>>> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+is%3Aopen+label%3A%22Training+Manual%22
>>>> [3] https://github.com/qgis/QGIS-Training-Data/pull/17
>>>> Regards,
>>>> Harrissou
>>>> Le jeu. 3 janv. 2019 à 13:22, Janneke van Dijk <janneke.qgis at gmail.com>
>>>> a écrit :
>>>>> Dear all,
>>>>> I'm currently going through the QGIS 3 training manual
>>>>> (https://docs.qgis.org/testing/en/docs/training_manual/) using QGIS
>>>>> 3.4.3 and documenting any changes that would still need attention. I
>>>>> understand that it's a work in progress and hope/plan to contribute a
>>>>> bit in a later stage. What is complicating matters is that the data
>>>>> that
>>>>> I downloaded (QGIS-Training-Data-2.0.zip) does not contain all the
>>>>> layers that are mentioned (so far schools, restaurants,
>>>>> network_analysis
>>>>> folder and possibly some more that I may have skipped). Is there a
>>>>> complete/up-to-date data set available? Where can I find it?
>>>>> Thanks for any suggestions,
>>>>> Janneke
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Qgis-community-team mailing list for organizing community resources
>>>> such as documentation, translation etc..
>>>> Qgis-community-team at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>> Alexandre Neto
>>> @AlexNetoGeo
>>> http://sigsemgrilhetas.wordpress.com
>>> http://gisunchained.wordpress.com
>> Alexandre Neto
>> @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20190107/c6f2b0b4/attachment-0001.html>
More information about the Qgis-community-team
