[Qgis-community-team] Documentation wish list for "hackfesters"
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Mon Sep 16 09:19:59 PDT 2019
Hi Harrissou!
How are you? Thanks for the reminder.
During the hf I've been working quite some time on the cookbook, to be
exactly on the vector-layer page I started with in A Coruna. I'm halfway
now, at the part where "Symbology" starts. Should I put it in a branch
and share it already? I kind of hope that the symbology part will be
easier and faster.
Kind regards,
Raymond
On 16-09-19 17:57, DelazJ wrote:
> Hi all,
> The hackfest has gone for weeks, but QGIS is still there as well as
> writers and developers. So I wonder if someone had considered the
> opportunity to give a hand on any of the identified issues.
> /NB: It could not be for the "Spare Time Inc" since we still have
> unallocated funds (and not "founds" - damn keyboard)./
> Regards,
> Harrissou
> Le ven. 23 août 2019 à 18:21, DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>> a écrit :
>     Hi all,
>     With the QGIS Community Meeting beginning, a bunch of developers and
>     writers will meet to brainstorm and improve QGIS. Here are some
>     suggestions of topics (among many others) some documentation
>     contributors would be REALLY interested in having a fix for. We need
>     a developer to address and ease our "life" (sounds tragical enough?
>     :D ). Well.
>     In short:
>     1/ *Improve the automatic creation of screenshots* [1]
>     2/ *Redirect docs links *and ensure that changing links in docs does
>     *not break the help button* in application [3]
>     3/ *Document/improve the doctest architecture for PyQGIS Cookbook
>     *(kind of [4])
>     For the details:
>     1/ QGIS is moving fast. Dialogs are changing at every release,
>     making screenshots in the docs obsolete. There was a plan to avoid
>     writers manually take each screenshot, and instead generate them in
>     series, browsing tabs of a specified dialog eg. A work had been
>     initiated in the QgsAppScreenshots class [1]. It could be nice to
>     get more news on it.
>     Incidentally, with such a feature, we can expect more translated
>     screenshots (which may not be good for our server but helpful for
>     non-English readers and translators).
>     2/ Because features are getting bigger, we sometimes need to
>     reorganize the chapters in documentation in order to match how
>     things behave in the application and also avoid very loooong
>     chapters. Moving sections or renaming them (to match their actual
>     scope) breaks the Help button associated to the feature, for at
>     least three releases (the next-to-be LTR and the two previous
>     versions since they point to the same doc). To fix that, doc writers
>     have to update the links in the code and this change only applies to
>     current release(s), not for EOLed one (eg 3.6 could have more not
>     working links than 3.8 or master - we have a script for checks [2]).
>     We need to find a more viable way to address this issue and redirect
>     requested links to their actual place in the corresponding doc.
>     This issue is a long standing one that has been reported/discussed a
>     couple of times already (eg [3] has some suggestions)
>     3/ During the La Coruna hackfest, a doctest infrastructure has been
>     set up to ensure code samples provided for PyQGIS Cookbook are still
>     working. Months later, it looks to me like it's less used than it
>     should:
>       - partly, because we did not make it mandatory,
>       - partly because it does not apply (or we did not figure out how?)
>     in some cases. Eg it seems it does not know about iface [4]. Also
>     there are test projects the system should rely on but nobody uses it
>     and afaics there's no example someone not used to this could follow.
>     It could be nice clarifying the system and help writers adopt it.
>     [1] https://github.com/qgis/QGIS/blob/master/src/app/qgsappscreenshots.h
>     [2] https://github.com/qgis/QGIS/blob/master/scripts/chkdoclink.sh
>     [3]
>     https://github.com/qgis/QGIS-Documentation/pull/2258#issuecomment-352246124
>     [4] https://github.com/qgis/QGIS-Documentation/issues/3776
>     Et voilà... Sorry to have been long. Looking forward...
>     And for information, docs still have unallocated founds...
>     Happy hackfest,
>     Harrissou
> Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team
