[Qgis-community-team] Documentation: atlas feature clipping settings : clip to item
    DelazJ
    delazj at gmail.com
    Sat Nov 21 13:02:56 PST 2020
Hi Larissa,
While clip to atlas feature uses a layer, clip to item uses a layout item;
you need to add shape like rectangle, ellipse, triangle (anything else? I
did not check) to the layout in order to have something available to clip
the map item
See also
https://qgis.org/en/site/forusers/visualchangelog316/index.html#clip-layout-maps-to-shape
Hope that helps,
Harrissou
Le sam. 21 nov. 2020 à 11:10, Larissa Junek <l.junek at gmx.net> a écrit :
> Hello folks,
> does somebody have experience in clipping a map to an item in the print
> composer atlas feature?
> While clip to atlas feature works fine, I'd like to know how to work
> with the "clip to item" setting in the map item properties.
> Regards, Larissa
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20201121/920c3aef/attachment.html>
More information about the Qgis-community-team
