[Qgis-community-team] pdf testing build failing
DelazJ
delazj at gmail.com
Fri Mar 4 01:46:35 PST 2022
Hi Richard,
The gif in recent docs not available in 3.16 that I can think of is
https://github.com/qgis/QGIS-Documentation/blob/master/docs/user_manual/introduction/img/map_navigation.gif
Worth trying a build without?
Regards,
Harrissou
Le ven. 4 mars 2022 à 09:10, Richard Duivenvoorde <rdmailings at duif.net> a
écrit :
> Hi, Any Latex/PDF guru's here?
> The pdf build of current testing version of the docs is failing.
> Normally we do a Latex build and after that a pdf generation.
> 3.16 is still fine (build yesterday I see in pdf of 3.16)
> But building testing here locally:
> Latex build is fine, then pdf generation generates output below.
> I'm thinking about a poissonous GIF image? Anybody aware of maybe animated
> gifs or so?
> See below for the build error
> Regards,
> This is XeTeX, Version 3.141592653-2.6-0.999993 (TeX Live 2022/dev/Debian)
> (preloaded format=xelatex)
> \write18 enabled.
> entering extended mode
> Error: /undefined in GIF89ax��
> Operand stack:
> Execution stack:
> %interp_exit .runexec2 --nostringval-- --nostringval--
> --nostringval-- 2 %stopped_push --nostringval-- --nostringval--
> --nostringval-- false 1 %stopped_push 1990 1 3 %oparray_pop
> 1989 1 3 %oparray_pop 1977 1 3 %oparray_pop 1833 1 3
> %oparray_pop --nostringval-- %errorexec_pop .runexec2
> --nostringval-- --nostringval-- --nostringval-- 2 %stopped_push
> --nostringval--
> Dictionary stack:
> --dict:770/1123(ro)(G)-- --dict:0/20(G)-- --dict:75/200(L)--
> Current allocation mode is local
> Current file position is 12
> GPL Ghostscript 9.55.0: Unrecoverable error, exit code 1
> xdvipdfmx:fatal: pdf_link_obj(): passed invalid object.
> No output PDF file written.
> \write18 enabled.
> Operand stack:
> Execution stack:
> --nostringval--
> Dictionary stack:
> Qgis-community-team mailing list for organizing community resources such
> as documentation, translation etc..
> Qgis-community-team at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20220304/e88c9d4d/attachment.html>
More information about the Qgis-community-team
