[Qgis-community-team] Project hub's size limitation
Régis Haubourg regis.haubourg at gmail.com
Sun Oct 27 08:53:10 PDT 2024
ok got it.
Can you open an issue in https://github.com/qgis/QGIS-Django and ping
@xpirix there?
He will probably be able to help you .
Cheers!
Le dim. 27 oct. 2024, 10:10, Erez Sarig <erez.sg at gmail.com> a écrit :
> Hi sure. the geopackes/projects hub in this link
> https://plugins.qgis.org/geopackages/
> Thanks!
> On Sun, Oct 27, 2024 at 10:38 AM Régis Haubourg <regis.haubourg at gmail.com>
> wrote:
>> Hi. Can you specify what hub you are referring to?
>> Le dim. 27 oct. 2024, 08:17, Erez Sarig via Qgis-community-team <
>> qgis-community-team at lists.osgeo.org> a écrit :
>>> Hi.
>>> I'm failing to upload a gpkg with some scripts and tools to the QGiS
>>> projects hub because of a 1MB size limit.
>>> I really tried shaving it off or zip it in different ways but always
>>> came up with at least 1.5MB. I believe it's worth the few extra MB and I
>>> would hate not to publish it just because of this small size difference.
>>> Thanks a lot. Erez Sarig
>>> Qgis-community-team mailing list for organizing community resources such
>>> as documentation, translation etc..
>>> Qgis-community-team at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20241027/623d8ff6/attachment-0001.htm>
More information about the Qgis-community-team mailing list
