[Qgis-developer] can't respond to my bugs by the link in a
message from Trac
Maciek Sieczka
werchowyna at epf.pl
Mon Apr 3 14:59:02 EDT 2006
On Mon, 3 Apr 2006 10:42:49 -0800
sherman at mrcc.com wrote:
> On Mon, Apr 03, 2006 at 08:25:37PM +0200, Maciek Sieczka wrote:
> > BTW: what do I do in order to access my bug report in now?
> > In the email from Qgis bug tracking system I was told:
> > > You can respond by visiting:
> > > https://sourceforge.net/tracker/?func=detail&atid=478378&aid=1245967&group_id=55820
> That message is from the SourceForge bug tracker which we no longer
> use. Bugs should be filed at https://svn.qgis.org/trac.
So I shouldn't be advertised to use the link which is wrong, like this:
All the folks who don't follow the qgis dev list enough/at all will
have the same problem. Their eventuall reply might never reach you,
depending on how much they care. I cared to ask on dev list and now I
know. They won't.
> We haven't migrated existing bugs from SF to the new system. You can
> either refile the bug or wait until we sort through them and import
> the old ones.
Recently I got few emails from Radim via bug tracker, (I don't know if
via Trac or the old system) in which I'm asked to reply to those
emails using https://sourceforge.net/tracker/ in order to provide
additional info as requested by Radim. But it doesn't work.
What do I do so that my replies regarding my bugs, on which Radim is
working now, are stored in Trac from now on?
> Also note - the mailing lists have moved as well. You should use the
> new mailing lists described at http://qgis.org.
OK, got it now. I used qgis-developer at lists.sourceforge.net because
that's what the bug tracking system used when contacting me.
Maciek
"JUGOMA" Biuro Rachunkowo - Doradcze obs?uguje firmy krajowe i zagraniczne w pe?nmym zakresie: doradztwo,ksi?gowo??,organizacja firmy,
pos?ugujemy si? angielskim, niemieckim. Zapraszamy na stron?! http://www.jugoma.friko.pl/
