[Qgis-developer] Unit test reports
Tim Sutton tim at linfiniti.com
Tue Apr 11 12:01:08 EDT 2006
Hi
Just an update on the unit tests....
I have now build stubs for core, raster and gui libs (Ill be adding
others soon). Ive made a script in tests/src/runtests.sh that will
iteratively run all tests and produce a report as shown attached.
Now we need to start making concrete test implementations....
We could consider a few options:
 - if you change a method, write a simple test to accompany your
change in the stub provided, so next time you make a change we have
something to verify the change with.
- if you add a method,write a simple test to accompany your change (no
stub will exist obbiously) , so next time you make a change we have
Ill be experimenting with the gui automation test facilities next and
then Ill write some HOWTO on creating both non gui and gui tests using
the test framework.
Regards
Tim
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060411/5f7b7519/qgistest.11Apr2006_1652.html
