[Qgis-developer] custom projection definition
Jachym Cepicky jachym.cepicky at centrum.cz
Wed Aug 23 04:41:43 EDT 2006
Hallo,
maybe i do something wrong, but:
I would like to define my custom projection "Krovak  S-JTSK" with
following parameters:
Parameters: +proj=krovak +ellps=bessel +no_defs +towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
It is not possible to add custom projection to QGIS. When I click on the
"Save" button, nothing is saved.
when I try to add just something common:
Parameters: +proj=latlong +ellps=WGS84
It can not be saved either.
In sqlite:
sqlite> select * from vw_srs;
sqlite>
In the command line, only two lines appear:
QgsCustomProjectionDialog::getProjFromParameters()
QgsCustomProjectionDialog::getEllipseFromParameters()
And, I would say, the test does also not work, how expected:
I would say, that North and East are changed
and
when I try
North: 12
East: 24
the result is
0.2084
0.4189
is it wrong, that I'm expecting "12 14" ?
echo "12 24" |cs2cs +proj=latlong +to +proj=latlong +ellps=WGS84
12dE    24dN 0.000
short summary:
1) It is not possible to save custom projection
2) the "test" of custom projection does not work properly
qgis_unstable 0.8 fresh svn, build with dpkg-buildpackage on ubuntu 6.06
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060823/69487603/attachment.bin
