[Qgis-developer] Cannot print lines to postscript
Maciej Sieczka
tutey at o2.pl
Tue Dec 5 17:01:49 EST 2006
Radim Blazek wrote:
> I cannot print line layers to Postscript/Pdf. drawPolyline is called,
> but no lines are is written (I tried to diff files). It works on screen
> and when printing to raster image.
> Can you confirm this problem?
No. With your and Martin's recent fixes I'm now able to print to pdf,
ps and eps! Hooray! And lines are rendered OK.
The only glitch still remaining for me, which I also have mentioned in
the #345 in Trac, is that although the "Print to file" is checked by
default, the dialog for entering the path to file is not active;
printers are listed instead; see the attached screenshot.
I have to uncheck it and check it back for the path dialog to become
active.
QT 4.2.2, QGIS SVN 6190
Maciek
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20061205/e51076c6/printerVSfile.png
