[Qgis-developer] Re: [Qgis-user] Re: Re: Re: Re: Re: Error in
print: Cannot find BoundingBox
Maciej Sieczka
tutey at o2.pl
Wed Dec 6 16:50:37 EST 2006
Radim Blazek wrote:
> Try again with today fix. The problem was that Qt decided the format
> once during the session so for example after printing one pdf file
> the format was still pdf even if file name had ps/eps extension.
I still have a related problem with SVN 6195, but slightly different.
When I start QGIS the default filetype in print composer is PDF. I set
up a map, specify a path to an EPS file - then I get the infamous
errors: "cannot find boundingbox" and "cannot find translate". But, if
I let QGIS print to PDF once, from then on printing to *any* format
becomes possible in the current session - be it PDF, PS or EPS. What
the devil?
> Because the QPrinter::outputFormat() is also buggy it was impossible
> to get info whic format is used.
> I have disabled default output to file and no it seems to work,
> you have to check output to file always but the format correspond
> to the extension.
That's better now, thanks.
Moreover I noticed map composer works way faster now, and the artifact
lines when rendering polygons are gone. Great!
Maciek
