[Qgis-developer] Patch for compiling qgis-0.8pre2 with
geos-3.0.0rc3
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sat Dec 16 02:39:38 EST 2006
Ok,
For some reason, adding /usr/lib64/qt4/bin to the path didn't do the
trick...I actually had to add a links to qmake and lrelease /usr/bin as
Gavin suggested. It just seems strange that prerelase 2 had no problems
for me like this, but now the current version does...
FWIW, I've attached a patch for the current unstable source with the
extra changes I needed to get it to work with GEOS 3.x. This took a
couple more changes to get working. I had to include references to
TopologyException.h in qgsgeometry.cpp and qgsogrprovider.cpp, and make
a couple changes to the catch statements that used the TopologyException
class.
Also, it seems I still needed to add a symbolic link to the new geos
library for it to compile like so:
ln -s /usr/lib64/libgeos-3.0.0rc3.so /usr/lib64/libgeos.so.2
Anyway, I hope somebody finds this useful.
Regards,
Mike
Gary Sherman wrote:
> On Dec 15, 2006, at 8:10 PM, Mike Leahy wrote:
>> My qmake and lrelease binaries for qt4 are located in
>> /usr/lib64/qt4/bin. Is there something I need to do to tell it to
>> look there?
> You just need to make sure that /usr/lib64/qt4/bin is in your path when
> you run configure. The create_qm_files.sh script should get set up to
> reference that path during the configure process.
> -gary
> -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> Gary Sherman
> Micro Resources: http://mrcc.com
> *Geospatial Hosting
> *Web Site Hosting
> "We work virtually everywhere"
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20061216/bd18ecfb/qgis-unstable-rev6267-geos-3.0.0.bin
