[Qgis-developer] Mac OS X vertex limitation
    William Kyngesburye
    woklist at kyngchaos.com
    Sun Dec 31 19:52:59 EST 2006
There's a note in the Mac Qgis readme about the Mac build being
limited in the number of vertices per polygon due to a QuickTime
limitation (actually that's a QuickDraw limitation) as used in Qt.
Is this still valid?
I looked at the Qt docs for QPainter and Qt4 should be able to use
OSX's CoreGraphics now.  Unless maybe Qgis is still using a Qt3
compatibility thing and stuck on the QuickDraw method?  Though I'm
not sure if CoreGraphics has removed that vertex limitation or not
(one would think so).
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
