[Qgis-developer] updating data from multiple algos simultaneously
on canvas
nitin quick
quick.nitin at gmail.com
Wed Jul 5 06:04:28 EDT 2006
hello everybody
i am using QGIS 0.7.9
Aim of my plugin: To display points received from various algorithms
simultaneously on canvas.
Situation is like on top of map i am displaying location of points received
from a client-socket using TCP/IP. It works fine till only one such socket
is opened and read from .Updation and movement of points goes well. But as
soon as i start reading from multiple client/sockets and try to display data
, all situation goes awery. Then only data from recently activated
socket/client is updated and displayed. This is where i am looking for help.
How i have implemented: For storing data from various socket i am using
QHash with key as socket Descriptor id and Value as in a QList.
For each readyRead() received signal i gets i add in hash with correspondent
socket descriptor as key.
here is part of code i am putting:
// this slot will be called for newConnection() signal
void tcpCock::activatingNewConnection()
tcpSocket=tcpServer->nextPendingConnection();
connect( tcpSocket, SIGNAL(disconnected()),tcpSocket,
SLOT(deleteLater()));
connect( tcpSocket,SIGNAL(readyRead()),this,SLOT(updatePixmap()));
//provide a connect for linking socket exiting status to one of slo
which disconnects drawShape() from refresh signal.
connect(
tcpSocket,SIGNAL(disconnected()),this,SLOT(socketDisconnected()));
pIntQlist= new QList<int> ;
hash.insert(tcpSocket->socketDescriptor(),pIntQlist);
//drawshape() function defination for QgsMapCanvasItem's pure virtual one
void tcpCock::drawShape(QPainter & p)
//load the pixamap to be displayed
QString myFileNameQString= "/home1/qgis/images/cock/cock.png";
QPixmap myQPixmap;
myQPixmap.load(myFileNameQString);
QHashIterator<int, QList<int>* > itr(hash);
while ( itr.hasNext())
{ itr.next() ;//possible outcome of error
//tempList=itr.value();
QListIterator<int> tempListItr(*itr.value());
tempListItr.toBack();
y=tempListItr.previous();
x=tempListItr.previous();
QgsPoint qpt(x,y);
QPoint pt=toCanvasCoords(qpt);
move(pt.x(),pt.y());// added to check for movement of all
elements-questionable
p.drawPixmap(pt.x(),pt.y(),myQPixmap);
//This slot will be called for every readyRead()signal
void tcpCock::updatePixmap()
QTcpSocket *tempSock=dynamic_cast<QTcpSocket *>(sender());
if(tempSock)
QHash<int, QList<int>* >::const_iterator itr=hash.find
(tempSock->socketDescriptor());
QString st;
QDataStream in(tcpSocket);
in.setVersion(QDataStream::Qt_4_0);
if( tempSock->bytesAvailable() <= 0 )// changed from tcpSocket since
tcpsocket will look for newely activeted connection only
//cout<<"\nNothing Available for reading";
return;
in >>st;
int i=0;
QChar *data = st.data();
while (*data!=' ')
++data;
i++;
QString s1=st.left(i);
x=s1.toInt();
QString s2=st.mid(i+1);
y=s2.toInt();
itr.value()->append(x);
itr.value()->append(y);
move(x,y);
QgsRect r=mQGisApp->getMapCanvas()->fullExtent();
setRect(r);
show();
updateCanvas();
What i feel is not ok with this piece of code is i am not able to address to
canvas item corresponding to data received from each client. To avoid it
i am drawing each canvas item again at their last available location in
hash.value() ie list. But output is that only newely created socket -canvs
item is updated.
While using gdb i observed with 3 client connections. Every canvas item
starts again from location provided by newly activated client. and after
that all follow the path.
kindly help me in this matter.
regards
quick nitin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060705/b2bf640e/attachment.html
