[Qgis-developer] PKG_CHECK_MODULES / pkg-config
William Kyngesburye woklist at kyngchaos.com
Thu Jul 6 09:44:41 EDT 2006
I get the same thing on Mac OS X.  No pkg-config installed for me,
and I don't want to.
I ended up commenting out that line (there's actually a couple of
them I think) so I could build without pkg-config.  I didn't want to
use the suggestion of installing pkg-config just for this.
On Jul 6, 2006, at 6:44 AM, Radim Blazek wrote:
> Hi,
> my configure (without --with-qt-pkg-config) fails with:
> /configure.orig: line 9149: syntax error near unexpected token `QT,'
> ./configure.orig: line 9149: `    PKG_CHECK_MODULES(QT, QtCore QtGui
> Qt3Support QtNetwork QtXml QtSvg QtTest >= $QT_MIN_VER)'
> I have pkg-config version installed (version 0.20) on Ubuntu  6.06 LTS
> (Dapper Drake).
> It seems that PKG_CHECK_MODULES simply is not defined and consequently
> bash fails even if the block is not processed.
> Is it necessary to use PKG_CHECK_MODULES? It seems to be just another
> shit like all the auto* staf is.
> Radim
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
