[Qgis-developer] QGIS 0.8 requires an update to sterea [was: Re:
0.8; here I go]
Maciej Sieczka
tutey at o2.pl
Wed Jul 26 15:54:57 EDT 2006
Maciek Sieczka napisal(a):
> On Wed, 5 Apr 2006 00:06:57 +0100
> "Tim Sutton" <tim at linfiniti.com> wrote:
>>> 2.
>>> Settings, Project properties, Projection:
>>> SRIDSs 172-175 (EPSG 2170-2174) declare "+proj=stere", while it
>>> should be "sterea". Eg.:
>> 8<-----------snip -------------
>>> Maciek
>>> Should I fill bug reports in Trac?
>> Bug reports are good. Bug reports accompanied with fixes are even
>> better! You will find under the svn checkout two sqlite.db files under
>> qgis/resources
>> qgis.db is the template for user database of srs's (its blank to start
>> with for each user)
>> srs.db is the system wide srs database.
>> You are welcome to provide patches for the latter in the form of sql
>> insert / update statements.
I have at least extracted all the projections which require updating
from +proj=stere to +proj=sterea in QGIS 0.8.
In Proj 4.5 beta and Gdal 1.3.2 sterea is used in GDAL for 14 European
stereographic grids (18 listed below, but 4 are duplicate "deprecated"):
$ grep -B1 '+proj=sterea' /usr/local/share/proj/epsg | awk '/^#/ {print}
/^</ {print $1" "$2}'
# NAD83(CSRS98) / New Brunswick Stereo (deprecated)
<2036> +proj=sterea
# Pulkovo 1942(58) / Poland zone I (deprecated)
<2171> +proj=sterea
# Pulkovo 1942(58) / Poland zone II
<2172> +proj=sterea
# Pulkovo 1942(58) / Poland zone III
<2173> +proj=sterea
# Pulkovo 1942(58) / Poland zone IV
<2174> +proj=sterea
# ATS77 / New Brunswick Stereographic (ATS77)
<2200> +proj=sterea
# ATS77 / Prince Edward Isl. Stereographic (ATS77)
<2290> +proj=sterea
# NAD83(CSRS98) / Prince Edward Isl. Stereographic (NAD83) (deprecated)
<2291> +proj=sterea
<2292> +proj=sterea
# NAD83(CSRS) / New Brunswick Stereo
<2953> +proj=sterea
# NAD83(CSRS) / Prince Edward Isl. Stereographic (NAD83)
<2954> +proj=sterea
<3120> +proj=sterea
# Pulkovo 1942(58) / GUGiK-80
<3328> +proj=sterea
# Deir ez Zor / Levant Stereographic
<22780> +proj=sterea
# Amersfoort / RD Old
<28991> +proj=sterea
# Amersfoort / RD New
<28992> +proj=sterea
# Dealul Piscului 1933/ Stereo 33
<31600> +proj=sterea
# Dealul Piscului 1970/ Stereo 70
<31700> +proj=sterea
It is necessary to update this in QGIS before 0.8 release to spare users
problems and possible data corruption.
Sorry I can't do it myself. I hope this tip helps though.
Maciek
