[Qgis-developer] QGIS 0.8 requires an update to sterea [was:
Re: 0.8; here I go]
Maciej Sieczka
tutey at o2.pl
Thu Jul 27 06:17:23 EDT 2006
Stephan Holl wrote:
> > This is a first one:
> > echo "UPDATE tbl_srs SET projection_acronym = 'sterea' WHERE
> > projection_acronym LIKE '%stere';"|sqlite3 resources/srs.db
> > The 'stere' in column parameter is even harder, but I cannot
It is not only about updating. Also deprecated should be removed (?) as
they contain errors (eg. the EPSG 2171 has a huge one), and their new
substitutes should be added (eg. 3120 is a fixed 2171). Moreover, there
are completely new systems, at least 3328 is.
Moreover 2, there've been other changes in the EPSG database in last
moths; the issues I'm reporting here is only one of them.
Cheers,
Maciek
P.S.
I'm resending this email as yesterday it was blocked by the
qgis-developer at lists.qgis.org spam filter. Propably this happens when
qgis-developer at lists.qgis.org in CC but doesn't when it's in TOO. Let's
see if it get's through this time...
P.S.2
Nope, all my replies to qgis-developer at lists.qgis.org are blocked by the
spam filter, saying:
<quote>
his is the Postfix program at host poczta.o2.pl.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to <postmaster>
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The Postfix program
<qgis-developer at lists.qgis.org>: host lists.qgis.org[207.44.204.65]
said: 554
Service unavailable; Client host [193.17.41.74] blocked using
bl.spamcop.net; Blocked - see
http://www.spamcop.net/bl.shtml?193.17.41.74
(in reply to RCPT TO command)
Reporting-MTA: dns; poczta.o2.pl
X-Postfix-Queue-ID: 5221A58088
X-Postfix-Sender: rfc822; tutey at o2.pl
Arrival-Date: Thu, 27 Jul 2006 12:10:32 +0200 (CEST)
Final-Recipient: rfc822; qgis-developer at lists.qgis.org
Action: failed
Status: 5.0.0
Diagnostic-Code: X-Postfix; host lists.qgis.org[207.44.204.65] said: 554
</quote>
Let's see what happens if I compose a brand new message instead of a
reply...
P.S. 3
No good. Let's see what happens when I don't CC anybody, just TO
qgis-developer at lists.qgis.org.
Maciek
