[Qgis-developer] Mac build error
Tom Elwertowski
telwertowski at comcast.net
Tue Jun 13 14:10:00 EDT 2006
Tim Sutton wrote:
> Hi Tom
> My turn to tap your brain now :-) Im trying to build on my macbook.
> g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I -I/sw/include
> -I/usr/local/include -g -O2 -DQT3_SUPPORT
> -I/usr/local/Qt4.1.3/mkspecs/default
> -I/usr/local/Qt4.1.3/lib/Qt3Support.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtCore.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtGui.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtNetwork.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtOpenGL.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtSql.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtSvg.framework/Headers
> -I/usr/local/Qt4.1.3/lib/QtXml.framework/Headers
> -I/usr/local/Qt4.1.3/include/QtDesigner
> -I/usr/local/Qt4.1.3/include/QtTest -I/usr/local/Qt4.1.3/include
> -D_REENTRANT -DQT_THREAD_SUPPORT -DNO_DEBUG
> -I../../widgets/projectionselector/ -I../gui/ -I../legend/ -I../ui/
> -I../core/ -g -O2 -MT libqgis_raster_la-qgsrasterlayer.lo -MD -MP -MF
> .deps/libqgis_raster_la-qgsrasterlayer.Tpo -c qgsrasterlayer.cpp
> -fno-common -DPIC -o .libs/libqgis_raster_la-qgsrasterlayer.o
> In file included from ../core/qgsfeature.h:28,
> from ../gui/qgsclipboard.h:25,
> from ../gui/qgisapp.h:50,
> from qgsrasterlayer.cpp:107:
> ../core/qgsgeometry.h:22:18: error: geos.h: No such file or directory
> Its wierd because core built ok which includes that file, and
> /sw/include (where geos.h) is in the g++ line above. I installed geos
> from fink using apt-get.
> Any ideas?
I'm puzzled by this as well. I would expect the -I/sw/include to be
sufficient.
A difference between core/Makefile.am and projectionselector/Makefile.am
is that libqgis_core_la_CXXFLAGS contains $(GEOS_CFLAGS) and
libqgsprojectionselector_la_CXXFLAGS doesn't. An extra -I/sw/include
from $(GEOS_CFLAGS) should be redundant but perhaps it's needed.
Another idea is to add -v which should echo the actual include path
assembled from all the options. This may provide some insight to the
failed search.
Although I first used fink, and later darwin-ports, when I wasn't very
familiar with *nix, I did have to struggle with obscure path issues.
After becoming more familiar with the *nix directory structure and build
tools, I eventually found it simpler to directly install all additions
or Apple-overrides into /usr/local.
Tom
