[Qgis-developer] flickering on display through plugin
Tim Sutton
tim at linfiniti.com
Fri Jun 16 10:21:53 EDT 2006
Hi
You could try bitblt ing your points onto the canvas? Which version
of qgis is your plugin written for? 0.8 will use qcanvas as a basis
for map canvas...
Regards
Tim
On 16/06/2006, at 00:28, nitin quick wrote:
> hello everybody,
> i currently working on a plugin which will dispaly points on
> current canvas with points read from a fifo.Plugin implementation
> is done as external plugin build tutorial. Plugin is also working.
> but i have problem of flickering. As i understood the interface for
> plugin building, after reading data i am calling for refresh of
> canvas using mQGisIface->getMapCanvas()->refresh() . After this i
> receives a signal which is renderComplete() which is connected to
> render(QPainter *). It is very similar to NorthArrow plugin
> functionality.reading from a fifo is done through a thread which
> signal to gui thread after reading data every second. i think i am
> refreshing to everydrawing refreshing is bound to happen. But as no
> of elements on canvas increases it becomes very odd and ugly . I
> want to avoid it. Any advices how i can improve on it a nd get rid
> of flickering.
> thanks
> quick nitin
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
