[Qgis-developer] Mac build issues when using William's graphicslibs and gislibs...
Tim Sutton tim at linfiniti.com
Sat Jun 17 09:05:35 EDT 2006
Hi William
Im tryng to build qgis on macbook using your graphicslibs and gislibs
packages. However as best I can tell, one of the configure scripts is
adding /usr/local/static/ to the lib search path. Do you have stuff
built into /usr/local/static/ on your machine where you prepared the
packages that perhaps hasnt made it into your packages?
Also Im curious about your xcode setup. Ive never used xcode aside
from installing it to get my command line build environment set up.
Is there an xcode project for qgis you could share? Does it have nice
facilities for interactive debugging etc?
Many Thanks
Tim
g++ -O2 -Wall -o .libs/qgis -framework ApplicationServices qgis-
main.o -Wl,-F/usr/local/Qt4.1.3/lib -framework Qt3Support -framework
QtCore -framework QtGui -framework QtNetwork -framework QtXml -
framework QtSvg -Wl,-bind_at_load  ../raster/.libs/
libqgis_raster.dylib -L/usr/local/Qt4.1.3/lib -L/usr/local/gislibs/
lib -L/usr -L/usr/lib -L/usr/local/baselibs/lib -L/usr/local/
graphicslibs -L/usr/local/graphicslibs/lib -L/usr/local/static/hdf4/
lib -L/usr/local/gislibs -L/usr/local/static/netcdf -L/usr/local/
static/netcdf/lib -L/usr/local/pgsql/lib -L/usr/local/mysql-libs/
lib ../legend/.libs/libqgis_legend.dylib ../composer/.libs/
libqgis_composer.dylib ./.libs/libqgis_gui.dylib /Users/timsutton/dev/
cpp/qgis/src/raster/.libs/libqgis_raster.dylib /Users/timsutton/dev/
cpp/qgis/src/legend/.libs/libqgis_legend.dylib /Users/timsutton/dev/
cpp/qgis/src/composer/.libs/libqgis_composer.dylib /Users/timsutton/
dev/cpp/qgis/src/widgets/projectionselector/.libs/
libqgsprojectionselector.dylib /Users/timsutton/dev/cpp/qgis/src/
core/.libs/libqgis_core.dylib /usr/local/gislibs/lib/libgdal.dylib /
usr/local/gislibs/lib/libproj.dylib -liodbc -lxerces-c /usr/local/
graphicslibs/lib/libjasper.dylib /usr/local/gislibs/lib/
libhdf5.dylib /usr/local/gislibs/lib/libsz.dylib -lmfhdf -ldf -
logdi31 /usr/local/graphicslibs/lib/libgif.dylib -lgeotiff /usr/local/
graphicslibs/lib/libtiff.dylib /usr/local/graphicslibs/lib/
libjpeg.dylib -lc /usr/local/graphicslibs/lib/libpng12.dylib -lnetcdf
-lcfitsio -lpam -lkrb5 -lreadline -lresolv -ldl /usr/local/gislibs/
lib/libdap.dylib -lcurl /usr/lib/libxml2.dylib /usr/lib/
libiconv.dylib /usr/local/baselibs/lib/libsqlite3.dylib -lpthread -lz
-lm -lssl -lcrypto ../core/.libs/libqgis_core.dylib -lQtDesigner /usr/
local/Qt4.1.3/lib/libQtTest.dylib /usr/local/gislibs/lib/
libgeos.dylib -lsqlite3
/usr/bin/ld: warning -L: directory name (/usr/local/static/hdf4/lib)
does not exist
/usr/bin/ld: warning -L: directory name (/usr/local/static/netcdf)
does not exist
/usr/bin/ld: warning -L: directory name (/usr/local/static/netcdf/
lib) does not exist
/usr/bin/ld: warning -L: directory name (/usr/local/mysql-libs/lib)
does not exist
/usr/bin/ld: can't locate file for: -lmfhdf
Tim Sutton
