[Qgis-developer] Problem building current Preview
Luca Casagrande
luca.casagrande at gmail.com
Mon Jun 19 13:54:45 EDT 2006
Got this problem buidling current preview:
I have used the same configure line i used for every SVN snapshoot I
downloaded:
./autogen.sh --with-qt-pkg-config --with-grass=/usr/local/grass-6.1.cvs/
Error from the configure process is this:
b /usr/lib/libNCSEcw.so /usr/lib/libNCSCnet.so /usr/lib/libNCSUtil.so /usr/lib/libjasper.so /usr/lib/libhdf5.so -lssl -lcrypto
/usr/lib/libmfhdf.so /usr/lib/libdf.so -lgeotiff /usr/lib/libtiff.so /usr/lib/libjpeg.so -lpng -L/usr/grass60//lib -lgrass_vect -lgrass_dig2
-lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_I -lgrass_gproj -lgrass_vask -lgrass_gmath -lgrass_gis
-lgrass_datetime -lpq -lz -lrt -ldl /usr/lib/libsqlite3.so -lpthread /usr/lib/gcc/i686-pc-linux-gnu/3.4.6/libstdc++.so -lutil
/usr/lib/gcc/i686-pc-linux-gnu/3.4.6/../../../../i686-pc-linux-gnu/bin/ld:
cannot find -lgrass_vect
collect2: ld returned 1 exit status
make[5]: *** [spit] Error 1
to me it seem that is looking for the grass_vect.so in /usr/grass60/
but the file is here:
# slocate grass_vect.so
/usr/local/grass-6.1.cvs/lib/libgrass_vect.so
Thx
Luca
Alle 06:44, domenica 18 giugno 2006, Gary Sherman ha scritto:
> I have created the Release-0_8-preview-1 tag in SVN. If you are
> preparing binaries for the preview release, please use this tag. You can
> check out the source using:
> svn co https://svn.qgis.org/repos/qgis/tags/Release-0_8-preview-1
"E' molto più bello sapere qualcosa di tutto, che tutto di una cosa (Blaise
Pascal)."
GENTOO-GIS Development Team
jabber: casagrande at jabber.linux.it
