[Qgis-developer] Better getNextFeature in vector providers
Martin Dobias wonder.sk at gmail.com
Sun Mar 19 19:23:52 EST 2006
On 3/18/06, Brendan Morley <morb at beagle.com.au> wrote:
> Martin,
> I had thought 0.8 is already in feature freeze; though my interpretation
> of that was "get WMS finished, not just started" (-:  Therefore I vote
> you do this in some post-0.8 branch.
Hi Brendan,
Gary has recently set feature freeze to March 31, he confirmed to me
on IRC that it's ok to do some more improvements until that date.
Personally I don't think these changes are very big and I can surely
finish it on time.
> Can I also suggest that as a result of me looking at what's required of
> a WFS implementation, I've realised that getNextFeature will soon have
> to deal with nested attributes (this is because the XML Schema
> specification allows it).  When reimplementing getNextFeature, please
> make sure it can be easily "scaled" to nested attributes in future.
I would say that nested attributes can be flattened easily: they can
get field indexes in the order as they appear in schema and their
names can reflect nesting, e.g. "level1:level2:level3" could be name
for an attribute nested two levels deep. Does this make sense to you?
> Finally Mateusz, QVariant can have user variants - therefore I'm not
> sure if the refactoring of getNextFeature is a good enough reason to
> drag in the "boost" dependency.
I guess that Mateusz meant that only one header from boost would be
needed, not the whole library. However after some thinking and looking
in QVariant sources, I don't think that we really need something like
boost::any and that QVariant will suffice - I didn't find any
inefficiencies in the implementation. The second reason is that we
should prefer Qt classes to make the code as consistent as possible.
Is this OK for everyone? Everything is in one call, allows to fetch
geometry or not, allows to specify what attributes to fetch
(identified by attribute index).
bool getNextFeature(QgsFeature& feature, bool fetchGeometry = true,
   std::list<int>& fetchAttributes = emptyList)
(emptyList will be static member of QgsVectorDataProvider, providing
default argument for the function)
Martin
> Brendan
> On Fri, 2006-03-17 at 16:23 +0100, Martin Dobias wrote:
> > Hi,
> > currently I'm playing again with searching and filtering features from
> > vector layers. Now, QgsVectorDataProvider has several access methods
> > for features:
> > - QgsFeature* getFirstFeature(bool fetchAttributes)
> > - QgsFeature* getNextFeature(bool fetchAttributes)
> > - QgsFeature* getNextFeature(std::list<int> const & attlist, int
> > featureQueueSize)
> > - bool getNextFeature(QgsFeature &feature, bool fetchAttributes)
> > Notes:
> > - getFirstFeature is redundant and nearly not used at all
> > - last getNextFeature call is probably the best since it doesn't
> > create QgsFeature every time, but it misses implementation in
> > PostrgreSQL, GRASS and GPX providers, so far not used at all in QGIS
> > - getNextFeature with list as a parameter specifies attributes we're
> > interested in
> > In my opinion it's not very practical and in case I need to access
> > only attributes I always get also geometry. Therefore I'd like to
> > suggest improving this interface for more flexible access. This is my
> > idea of how this should work:
> > Only one accessor: bool getNextFeature(QgsFeature& feature)
> > Feature that will be passed to getNextFeature could set:
> > - hasGeometry(bool)  -- default true
> > - hasAttributes(bool) -- default false
> > Accessor function will consider these flags and won't do actions which
> > are not required.
> > Also dealing with feature attributes should be improved - I've started
> > some work on this to at least make difference between string and
> > numeric values. This is not very good solution though. My opinion is
> > to use QVariant classes for values (or something similar).
> > Now question mainly on Gary: what is the current plan of 0.8 release?
> > Should we wait with more improvements until it's released? (I'd like
> > to implement filtering of vector layers to work with providers other
> > than PostgreSQL) Or what about creating 0.8 release branch for
> > bugfixes while development can go on in trunk?
> > Bye,
> > Martin
> > This SF.Net email is sponsored by xPML, a groundbreaking scripting language
> > that extends applications into web and mobile media. Attend the live webcast
> > and join the prime developer group breaking into this new coding territory!
> > http://sel.as-us.falkag.net/sel?cmd=lnk&kid0944&bid$1720&dat1642
> > Qgis-developer mailing list
> > Qgis-developer at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/qgis-developer
