[Qgis-developer] Re: Fonts in composer
Radim Blazek
radim.blazek at gmail.com
Thu May 18 10:50:10 EDT 2006
On 5/18/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> Heureka (maybe)!
> Because Qt4 QPainter supports floating point numbers I could
> remove QgsComposition::mScale (set to 1 for now).
> Consequently the font scaling factor QgsComposition::psFontScaleFactor
> became wrong. I tried to fix the problem with scaling again
> and hopefully I found solution, basicaly:
> QFont font;
> font.setPointSize ( size );
> QFontMetrics metrics ( font );
> if ( plotStyle() == QgsComposition::Postscript )
> font.setPointSizeF ( metrics.ascent() * 72.0 /
> mComposition->resolution() );
> painter.setFont ( font );
> painter.drawText ( x, y, text );
> That means the size of font in Postscript must be set to metrics.ascent()
> of original font size.
> I tested on Linux with many fonts and different sizes and the font height
> seems to be almost always correct and text length is mostly correct.
> Tom, could you test on Mac?
I was too optimistic about floating point support, they are still using
d->cpen.width() to set with in PS. How can they release such a shit?!
PDF is the same. Is it possible that nobody wants to print a line < 1 mm?
Radim
