[Qgis-developer] RE:Windows build, help wanted
Martin Dobias
wonder.sk at gmail.com
Tue Nov 7 07:12:31 EST 2006
Erm... this time I've tried to compile it I have hit several problems:
it wanted to compile without jpeg support, but make wanted to link it
with jpeg library, moreover some (or all?) of the compiled grass
programs have crashed.
Bad luck today for me :-/
On 11/6/06, godofredo contreras <frdcn at hotmail.com> wrote:
> Hi:
> This is the error log I got:
> GRASS GIS compilation log
> Started compilation: Thu Nov 2 02:47:14 GMT 2006
> Errors in:
> /src/grass-6.2.0/lib/pngdriver
> /src/grass-6.2.0/lib/raster
> /src/grass-6.2.0/lib/display
> /src/grass-6.2.0/lib/D
> /src/grass-6.2.0/lib/vask
> /src/grass-6.2.0/lib/edit
> /src/grass-6.2.0/lib/form
> /src/grass-6.2.0/display/d.ask
> /src/grass-6.2.0/display/d.barscale
> /src/grass-6.2.0/display/d.colorlist
> /src/grass-6.2.0/display/d.colors
> /src/grass-6.2.0/display/d.colortable
> /src/grass-6.2.0/display/d.erase
> /src/grass-6.2.0/display/d.extend
> /src/grass-6.2.0/display/d.extract
> /src/grass-6.2.0/display/d.font
> /src/grass-6.2.0/display/d.frame
> /src/grass-6.2.0/display/d.geodesic
> /src/grass-6.2.0/display/d.graph
> /src/grass-6.2.0/display/d.grid
> /src/grass-6.2.0/display/d.his
> /src/grass-6.2.0/display/d.histogram
> /src/grass-6.2.0/display/d.info
> /src/grass-6.2.0/display/d.legend
> /src/grass-6.2.0/display/d.linegraph
> /src/grass-6.2.0/display/d.mapgraph
> /src/grass-6.2.0/display/d.measure
> /src/grass-6.2.0/display/d.menu
> /src/grass-6.2.0/display/d.mon/cmd
> /src/grass-6.2.0/display/d.mon/pgms
> /src/grass-6.2.0/display/d.nviz
> /src/grass-6.2.0/display/d.paint.labels
> /src/grass-6.2.0/display/d.path
> /src/grass-6.2.0/display/d.profile
> /src/grass-6.2.0/display/d.rast
> /src/grass-6.2.0/display/d.rast.arrow
> /src/grass-6.2.0/display/d.rast.edit
> /src/grass-6.2.0/display/d.rast.num
> /src/grass-6.2.0/display/d.rgb
> /src/grass-6.2.0/display/d.rhumbline
> /src/grass-6.2.0/display/d.save
> /src/grass-6.2.0/display/d.text
> /src/grass-6.2.0/display/d.title
> /src/grass-6.2.0/display/d.vect
> /src/grass-6.2.0/display/d.vect.chart
> /src/grass-6.2.0/display/d.what.rast
> /src/grass-6.2.0/display/d.what.vect
> /src/grass-6.2.0/display/d.where
> /src/grass-6.2.0/display/d.zoom
> /src/grass-6.2.0/general/g.access
> /src/grass-6.2.0/general/g.mapset
> /src/grass-6.2.0/general/g.mapsets
> /src/grass-6.2.0/general/g.setproj
> /src/grass-6.2.0/general/g.transform
> /src/grass-6.2.0/imagery/i.ask
> /src/grass-6.2.0/imagery/i.class
> /src/grass-6.2.0/imagery/i.cluster
> /src/grass-6.2.0/imagery/i.gensig
> /src/grass-6.2.0/imagery/i.gensigset
> /src/grass-6.2.0/imagery/i.group
> /src/grass-6.2.0/imagery/i.his.rgb
> /src/grass-6.2.0/imagery/i.maxlik
> /src/grass-6.2.0/imagery/i.ortho.photo/libes
> /src/grass-6.2.0/imagery/i.ortho.photo/menu
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.2image
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.2target
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.camera
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.elev
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.init
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.rectify
> /src/grass-6.2.0/imagery/i.ortho.photo/photo.target
> /src/grass-6.2.0/imagery/i.points
> /src/grass-6.2.0/imagery/i.rectify
> /src/grass-6.2.0/imagery/i.rgb.his
> /src/grass-6.2.0/imagery/i.smap/shapiro
> /src/grass-6.2.0/imagery/i.target
> /src/grass-6.2.0/imagery/i.vpoints
> /src/grass-6.2.0/imagery/i.pca
> /src/grass-6.2.0/imagery/i.cca
> /src/grass-6.2.0/ps/ps.map
> /src/grass-6.2.0/raster/r.digit
> /src/grass-6.2.0/raster/r.le/r.le.setup
> /src/grass-6.2.0/raster/r.le/r.le.trace
> /src/grass-6.2.0/raster/r.profile
> /src/grass-6.2.0/raster/r.support/modcats
> /src/grass-6.2.0/raster/r.support/modhist
> /src/grass-6.2.0/raster/r.support/modhead
> /src/grass-6.2.0/raster/wildfire/r.spread
> /src/grass-6.2.0/raster/r.in.gdal
> /src/grass-6.2.0/vector/v.label
> /src/grass-6.2.0/vector/v.what
> Finished compilation: Thu Nov 2 03:05:08 GMT 2006
> (In case of errors please change into the directory with error and run
> 'make')
> the first two are related with png driver and I think is the problem why
> raster support is missing.
> The especific error messages are:
> OBJ.i686-pc-mingw32/Color_table.o(.text+0xe3): In function
> `init_color_table':
> C:/msys/src/grass-6.2.0/lib/pngdriver/Color_table.c:95:
> variable 'standard_color s_rgb' can't be auto-imported. Please read the
> documentation for ld's --enable-a uto-import for details.
> OBJ.i686-pc-mingw32/Color_table.o(.text+0xee):C:/msys/src/grass-6.2.0/lib/pngdri
> ver/Color_table.c:95: variable 'standard_colors_rgb' can't be auto-imported.
> Ple ase read the documentation for ld's --enable-auto-import for details.
> OBJ.i686-pc-mingw32/Color_table.o(.text+0x2a3): In function
> `PNG_Color_table_flo at':
> C:/msys/src/grass-6.2.0/lib/pngdriver/Color_table.c:118:
> variable 'standard_colo rs_rgb' can't be auto-imported. Please read the
> documentation for ld's --enable- auto-import for details.
> OBJ.i686-pc-mingw32/Color_table.o(.text+0x2b2):C:/msys/src/grass-6.2.0/lib/pngdr
> iver/Color_table.c:118: variable 'standard_colors_rgb' can't be
> auto-imported. P lease read the documentation for ld's --enable-auto-import
> for details.
> OBJ.i686-pc-mingw32/Color_table.o(.text+0x313): In function
> `PNG_Color_table_fix ed':
> C:/msys/src/grass-6.2.0/lib/pngdriver/Color_table.c:133:
> OBJ.i686-pc-mingw32/Color_table.o(.text+0x31e):C:/msys/src/grass-6.2.0/lib/pngdr
> iver/Color_table.c:133: variable 'standard_colors_rgb' can't be
> for details.
> collect2: ld returned 1 exit status
> make: ***
> [/src/grass-6.2.0/dist.i686-pc-mingw32/lib/grass_pngdriver.dll]
> Error 1
> I think it was solved in cvs, here is a post about that problem:
> http://www.nabble.com/lib-pngdriver-Mingw-compile-error-t2541925.html
> Here is a description of current problems with mingw native port :
> http://grass.gdf-hannover.de/wiki/WinGRASS_Current_Status
> Regards
> Freddy
> ________________________________
> Stay in touch with old friends and meet new ones with Windows Live Spaces
